Question about Danfoss Sundstrand-sauer-danfoss Sundstrand Hydraulic Pump
Need hyd Motor hyd p/n 23-3802 pump hyd p/n 23-2058 mfg sundstrand explain me, how to order and where? thks
    Problem Solver:
  • 11 Answers
Call Nova Hydraulics 317-322-0242 x103.
You will need the last 6 letters of your motor code.
A correct code example 23-3802AN-JSBJ.
Posted on Jul 02, 2010
User manual for sauer-sundstrand transaxle?
This is the only provider of repair manuals on that transaxle on line. I normally get the manuals from the dealer or a local repair shop but this site should provide you with what you need:
http://hydrostaticpumprepair.com/html/sundstrand_hydrostatic_parts_a.html
Nov 25, 2011 | Danfoss Sundstrand-sauer-danfoss...
Dear Sir, We have one Sundstrand Turolla-200 make Hydraulic Pump, Model: TFP-200/6D SC51 LAA/9B , which is not building up hyd. pressure more than 80 bar. We are also not getting source of supplier for...
First you need to find out if you have fluid in the cylinder,if low or empty it will not build up pressure.Hydraulics are famous for blowing seals and bleeding hydraulic fluid everywhere. If you have fluid its possible the switch valve is sticking to go up or down or not working. if that is working check the pump motor to see if the motor shaft is attatched to the pump
Feb 15, 2011 | Danfoss Sundstrand-sauer-danfoss...
I have a sundstrand pump, model 15-2078. It has 4 ports, I know the 2 that go to the hyd. motor. I am not sure which one is the suction and which one is the return
The suction is at the front of the pump by the input shaft. The inlet can be set up as RH or LH by simply moving the plug to the other side.
The case drain is at the back of the pump housing between the 2 ports on the end cap that go to the hydraulic motor. There are 2 case ports 180 degrees from each other.
May 28, 2010 | Danfoss Sundstrand-sauer-danfoss...
Charge pressure drops to zero when hot and grouls.Where is the charge pressure set? Jack
What is the model number and brand of your pump? Your description is a classic statement when hydros (your pump and motor) are failing. You can try charge pressure adj to make it work better. Model number will tell me where to direct you.
Mar 18, 2010 | Danfoss Sundstrand-sauer-danfoss...
I have a 3 stacked sauer hyd pump 1st one a spn3/55 d sc47 19m 2nd a snp2/17 d 3rd tfp100/3.2 d sc06/96 i'm looking for info an the flow gpm and pressure for each pump
Call Nova Hydraulics 317-322-0242 x 103 and you will get your information. What is the input rpm turning the pumps? The flow will vary depending on the input rpm.
Mar 13, 2010 | Danfoss Sundstrand-sauer-danfoss...
Sauer sundstrand gearbox seal TMG 61.2 L1 112B Serial no. PX043210667 Think no.on seal is 145 245 14 or could be 145 215 14 Regards Ivor Reid
The part numbers you are reading on the seal are the seal's dimensions in millimeters. I believe that the seal in the link below is what you are looking for. TMG Stands for Transit Mixer Gearbox. 61.2 is the gear ratio. The owners of Mixer & Plant Parts Mfg have been in the industry for over 40 years. Their phone number is 877-327-2116 and they can help you with virtually any concrete mixer part or concrete batch plant part:
http://www.mixerandplantparts.com/product-p/301010.htm
Feb 24, 2010 | Danfoss Sundstrand-sauer-danfoss...
We are using a4vg125....DA...EP2 series rexorth pump in our motor grader can we use your 90R series pump there than what are the possible changes we have to make for this arrangement.
I can possibly answer this question but I need the full model number of the rexroth pump. The a4g is a great pump. I have many years experience with the rexroth line. And possibly can help you.
Dec 10, 2009 | Danfoss Sundstrand-sauer-danfoss...
I need a Manual for a Sundstrand series 15 pump
I just found this free PDF. It is sundstrancd series 15 service manual. It certainly did not answer all my questions but its a good step forward.
www.cushmantrackster.com/pay-pdfs/sundstrand.pdf
Oct 10, 2009 | Danfoss Sundstrand-sauer-danfoss...
Looking for specs
You can get from BJ Hydraulics 269-623-6743
Jan 07, 2009 | Danfoss Sundstrand-sauer-danfoss...
Danfoss Sundstrand-sauer-danfoss Sundstrand Hydraulic Pump Logo
253 people viewed this question
Top Danfoss Garden Experts
frankrome
Tom Chichester
Are you a Danfoss Garden Expert? Answer questions, earn points and help others
