Question about Canon CanoScan LiDE 25 Flatbed Scanner
When I click "Open Scanner" the following message appears "Trying to open scanner session". It remains there for long time without opening the scanner. How to resolve this?
    Brigadier General:
  • 4,090 Answers
Uninstall and reinstall the driver
Please rate my help++++Thank for using FIXYA
Posted on Jun 03, 2010
Cc4 205 00000012
Sir/Madam
To solve this issue, please install the latest scanner driver. If you use MFL-Pro Suite Software,
  1. Click Start => Control Panel => Programs => Programs and Features.
  2. Select Brother MFL-Pro Suite from the list, click Uninstall and follow the on screen instructions.
  3. Once the uninstallation is completed, disconnect the interface cable and restart the PC.
If you do not use MFL-Pro Suite Software,
Make a temporary folder on your HDD to save the downloaded self-extracting file, e.g. C:\bront
Please click here to download the uninstall tool to remove the drivers.
Once downloading is completed, double click the downloaded file to extract it.
"ZIP Self Decompression" appears. Click DECOMPRESS.
"The decompression process was successful." will appear. Click OK.
A folder will be created in the temporary folder created in Step 1.
Open the folder and double click DelInf32.exe. "Brother MFC Uninstaller" dialog box will appear.
Select your model and click OK.
"Complete" will appear. Click OK.
Click here to download the latest "WHQL certified Printer Driver and Scanner Driver", and install it following the Install Instructions.
Or
Still Having Problem Then Go To Brother Printer Official Website :
When trying to scan using the Brother ControlCenter3 on Wind Brother
Or
Stll Having Brother Printer Problem Then follow Us For On:
Brother Printer Support
Jan 20, 2014 | Brother Office Equipment & Supplies
Scanner not working
Re-install the Scanner software.
Tallon41
Sep 08, 2012 | Canon PIXMA MX860 All-In-One InkJet...
I have an OCE Scanner CS4154 which is typically only used a few times a year. When it's being used, the scanner reports the following message: 100-32145 - Stitching between Camera B and C failed....
There could be a scratch on the white back ground / still remaining durt that is hard to clean. Open the lid and clean it's white background with a soft cloth. If the contamination is persistent, clean with a moist cloth and little soap. Then make sure to dry it with a soft dry cloth before closing the lid. Also clean both sides of the glass platen. Normally dry. When cleaned wet make sure no stripes remain on the glass platen. You can clean bottom side by lifting the glass platen on the back side. Then run the maintenance software. Should be installed on the PC where the scanner has been attached to. It will ask for the scanner calibration sheet (delivered with scanner). Do as aked by the program and the scanner should fine again.
Another possibility is Erase Parameter Blocks: Can be started from scanner maintenance program: Right click in the title bar and select Erase Parameter Blocks. Follow the instructions. Finally you need to recalibrate the scanner. The scanner maintenance program will instruct you to do so.
How old is the lamp? Sometimes I have to plug the scanner into a UPS (uninterrupted power supply) to fix a similar issue. Hope this helps.
Aug 29, 2011 | Office Equipment & Supplies
I lost my installation cd for my x2470 printer. I do not have money,is there a way to install it witout a cd
    • Step 1 Open your web browser and go to Lexmark's "Drivers and Downloads" page (see Resources section below). Locate the search box labeled "Search by Model" and enter X2470. Press return. Select your operating system from the pop-up menu. Wait for the download page to load, then click the "Download Now" button. Save the installer file to an easily accessible location.
    • Step 2 Rotate the printer so that the rear section is in view. Connect the power cord to the power cord connector located on the right. Plug the remaining end of the power cord into an electrical wall socket. Connect one end of the USB cable into the USB port located on the left. Rotate the printer back into place.
  • Step 3 Turn on your printer. Extend the paper guides and insert paper into the tray. Readjust the paper guides so that they are flush with the paper.
  • Step 4 Lift the scanner unit and wait for the print cartridge holder to move into view. Push down on the light blue lever to raise the cartridge holder lid. Install the ink cartridge into the print cartridge holder. Close the cartridge holder lid and lower the scanner unit.
  • Step 5 Connect the remaining end of the USB cable into any available USB port on your computer. If any "Add New Hardware" screens appear on your computer, click "Cancel."
  • Step 6 Open the previously saved installer file and follow the onscreen instructions.
  • Step 7 Locate the button on your Lexmark X2470 that looks like an open scanner pointing to a computer monitor. Press and hold this button for three seconds. Follow the instructions that appear on your computer. Once this is complete, your printer is ready for use.
May 23, 2011 | Lexmark X2470 All-In-One InkJet Printer
My new operating system doesn't recognize my scanner any longer but does do fine with the printer which are both the same machine. How do I fix that? I moved from Mac OX leopard to Mac OX snow leopard....
Shortly after the world started upgrading to Snow Leopard, reports began emerging that many Hewlett-Packard printers were incompatible with the upgrade. So, you can wait till you get the updated driver which is compatible with Mac Snow leopard.
Good Luck!
Aug 23, 2010 | HP Photosmart C7280 Laser Printer
On power up, unit begins to go thru calibration. Then freezes up. Display remains blank. Clicking is heard from scanner unit. Scanner bulb blinks on one end. Unplugging sometimes resets to the point it...
May be the scanner is not initialized. Disassembly the covers and take out the scanner section.Open it and clean the ash from mirrors.If not help you may change the scanner section.
Oct 09, 2009 | HP LaserJet 2840 All-In-One Printer
Help me pleaze
check if it connection issue
check all cables if it is connected directly
check device manager for imaging device see if there is a conflict update the driver
if same hotswap, then try another cable
if connection ok then same issue
trash and reinstall and reinstall the epson scan: follow this
Scanner Driver Removal
If you see a window that says User Account Control at any point, click Continue.
  1. Disconnect the USB cable from the printer and close any open windows.
  2. Click Start, then select Control Panel.
  3. In the window that opens, click Uninstall a Program under the Programs heading.
  4. Select Epson Scan, then click Uninstall/Change.
  5. Follow the on-screen instructions to complete the removal and restart your computer.
Once the removal is complete, please do the following:
Scanner Driver Download
  1. Go to www.epson.com select your contry
  2. Under All-In-Ones, select Flatbed, then select your model from the list.
  3. Click on Windows under Drivers & Downloads.
  4. Download the most current version of the Scanner Driver for your Windows operating system to your Desktop. Make a note of the file name in order to easily retrieve it.
Scanner Driver Install
  1. Double-click the downloaded file on your desktop.
  2. Click OK, Unzip, then OK again.
  3. Follow the on-screen instructions to complete the installation and license agreement. The installer will copy the files to the system.
  4. Click Finish when prompted.
  5. Turn your unit on and reconnect it to the computer after the installation is complete.
  6. Windows should detect new Hardware and complete the installation automatically.
  7. If a New Hardware Wizard appears, allow it to search automatically.
  8. If a message appears indicating The Scanner has not passed Windows Logo testing, click Continue Anyway. Then click Finish.
  9. Restart your computer before testing the scanner software.
Oct 09, 2008 | Epson Office Equipment & Supplies
ACER 620 P SCANNER
I Want Mercury Scanner 620P windows xp Driver
Aug 16, 2007 | AcerScan 620PT Flatbed Scanner
Canon CanoScan LiDE 25 Flatbed Scanner Logo
341 people viewed this question
old marine
old marine
