Flashing orange light on cpu
Orange flashing light on cpu. Cpu is not coming on or off.
  • Anonymous Jan 19, 2009
    I have the same problem as shown. I've tried to shut down but still can't start when I press the button.
    Any suggestion?
    Guru:
  • 1,342 Answers
Hold in your power button until the computer shuts off.
Turn it on again and see if it loads.
Posted on Apr 09, 2008
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
When i turn it on it only appears only a second , my monitor turn black
Hello Chelleydiao, hi, its either you have a CPU problem or the monitor itself. Check or use another monitor to see if the problem is fix. you see an blank monitor can also be caused by the CPU if it fails to boot. the aid the checking, do you see any orange light on the monitor? or any indication.... the led light on the screen in summary: green or blue means there is power and the CPU boots up. if orange the CPU fails to boot, if there are no lights on the Monitor panels, there are problems on the monitor. check these first....I need a much detail description.
Dec 18, 2010 | AOC Monitor
The light is on yellowe
Hello Qutey Babe, Hi.... the yellow light means there is no signal from the CPU. check your CPU.
Blue means normal, there is signal coming from CPU Yellow (orange usually). means no activity on the CPU,
Dec 06, 2010 | Acer AL1916W 19" LCD Monitor
Hi, when we turn on the PS3 the light goes green for no more than 2 seconds, flashes Yellow/orange and goes to red. Nothing comes on the screen. Where to from here? Lance
its call YLOD...just happen to me b4...u need to heat the 2 cpu n gpu with heat gun about 5mins with 400-500 degree..this procedure is to resolder the gpu/cpu.tQ
Oct 22, 2010 | Sony PlayStation 3 40GB System
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Rplaced power unit now the monitor will not come up with anything on it. Orange light blinking on front of cpu.
Make sure your monitor is connected to the proper video connection- that is if you have a video card in your machine and a video connection on your motherboard. If you connected to the motherboard and you have a video card -your screen will show nothing even though you are powered up. Dont know your situation, but just checking. Ive seen others do this.
Char S.
May 20, 2009 | Sony VAIO VGC-RB53 PC Desktop
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
Sony Screen Colors
it may not have problem of monitor first take the post (power on self test) to do so you have to disconnect 15 pin signal cable from cpu and power on it will give display without cpu the massage "no signal check signal cable" will appear then monitor is ok problem is in cpu. if no display come then problem in monitor
Oct 25, 2008 | Computers & Internet
Laptop won't turn on/stay on
Is the fan blocked?
If no air goes in, CPU could overheat.
Aug 26, 2008 | Toshiba Satellite 1135-S125 Notebook
Computers & Internet Logo
291 people viewed this question
David Payne
David Payne
