Question about Toshiba e-Studio120 Copier
Wrench and Snowflake
Pressed the clear/stop key but could not find the 8 key. What do I do once I get a code?
    Sergeant:
  • 329 Answers
Wrench means service problem. "snowflake" I assume you mean the developer symbol. Machien on - depres the clear key then the expose key then the clear key again then the expose key you are now in simualtion mode. depress 20 print 01 print this will turn of the maintenance or wrench code. Depress 24 print 06 print will clear the developer. turn on and off
Posted on Jun 12, 2008
Toshiba E studio 182 power initialization problem
On startup, if the machine shows a wrench-icon, press down "8" and "clear/stop" key simultaneously to show the exact error-codes. A list of detailed error-codes can be found here: http://officeimagingsystems.com/id175.html
Jun 27, 2014 | Toshiba E-Studio 182 Copy Machine
Wrench - no error code listed
CALL SERVICE (wrinch ) symbol appears, press the CLEAR/
STOP and "8" keys simultaneously and the corresponding error code will be displayed.
Jan 06, 2011 | Toshiba E-STUDIO 850 Copier
Rear brakes spoungy + rear tail light comes on for no reason
1/ How's the brake pads? High or low?
2/ How's brake pedal? In good shape and condition?
3/ How's brake switch conditions? Good?
4/ Sounds like there is air bubbles in brake system, get a friend if you never done any purging/bleeding brake lines before hand..
Find a small size clear air hose fit tightly over brake nipple on the caliper, tie it tight with twist-ties, stuck other end into a catcher or clean clear container, use a size 8 sock wrench loosen brake nipple slightly, pump the brake pedal until it can not be pressed anymore, keeping it pressed down, using your other hand release the nipple nut so brake fluid can flow out and into container, automatically your pedal will goes down and fluid will stop flowing then close nipple and repeat process until all fluid are flowing clear of bubbles. If brake fluid reservoir is low, keep topping-up with fresh brake fluid until you see a clear brake fluid flows out from the brake nipple. Once that happens, tighten the nipple and you should be in orime state to ride again. Good enough?
Apr 30, 2010 | 2008 Triumph America
Toshiba e-studio 45call for service 254292
Press "clear/stop" and "8". While holding this combination of keys down, an error code will be displayed....what code are you getting?
Sep 15, 2009 | Toshiba e-Studio 45 Black and White Copier
Getting a red ''wrench'' symbol, spits out blank page when making copy, error message to turn off/on main switch which we have done, but doesn't clear the error. The red ''wrench'' symbol keeps coming...
Press "clear/stop" and "8" at the same time. An error code will be displayed as long as these two buttons are held down. What is the error code? Let me know, please.
Sep 01, 2009 | Lanier Office Equipment & Supplies
Toshiba 13160 copier, wrench sign on what should i do
press the clear/stop button and the 8 key at the same time and a code will be displayed.. try that
Apr 30, 2009 | Toshiba 1360 Black and White Copier
I got a 2002 mercury cougar and there is a light that turns on an off once in a while it's the second 1 next to the wrench it looks like a snow flake what dos it mean
The yellow/orange snowflake means its between 42 and 33 degrees and the red snowflake means it's 32 degrees or below (fahrenheit).
Jan 28, 2009 | 2002 Mercury Cougar
Canon IR 2016
Additional Functions>2 key>8 key>Additional Functions (each key is pressed seperately, unlike regular iR copiers) Go to Copier>Functions>Clear> Err_ or Err_Clr. An E000 is a fuser code.
Aug 29, 2008 | Office Equipment & Supplies
CURRENTLY HAVE A WRENCH SHOWING AND SNOW FLAKE CIRCLE?
press the clear/stop and 8 key, and get the code
Mar 20, 2008 | Toshiba e-Studio120 Copier
229 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
