Question about Kohler 12 kW Emergency Power System - 12RES-L
12RES GEN.NAT.GAS FAILS TO START BY STRT BTTN AND TRNSFR SW
BATTERY AND ELECTRICAL ARE GOOD. IF I JUMPER 12 VOLTS TO STARTER SELINOID THE MOTOR TURNS OVER RAPIDLY BUT IF THE CONTROL PANEL TRIES TO START, IT CLICKS IN RAPID SUCESSION THEN STOPS AND GIVES OVER CRANK ERROR CODE. IT REMINDS ME OF WHEN YOU CRANK A CAR WITH LOW BATTERYAND THE VOLTAGES DROPS BECAUSE IT CAN'T HANDLE THE AMP LOAD
  • parlapanov Jun 03, 2010
    What do you mean by "rapid succession" 3-5 times - 1-5 s starting impulse?
    Scholar:
  • 142 Answers
If the succession is 3-5 sec crank - 3-10 sec pause, it is OK, but the cranking is not successful (the reason should be investigated).
If the succession is more rapid 1 - 2 sec you may have bad PCB control.
Posted on Jun 14, 2010
My kohler 12res starts but governor moves constantly which makes my voltage erratic
this is a common complaint to these , what it boils down to is allways a fuel problem , if its gasolene then its in the carb if it's nat gas then it's in the regulator/vaporizer
you'll have to clean these items to see if that helps . someof those liguid cleaners sometimes works but i find a good dissassembly cleaning to be the best
Jan 28, 2015 | Kohler 12 kW Emergency Power System -...
Bownes lawn tractor wont turn over. Battery fully charged and all safety switches were changed. its a briggs and stratton 12 1/2 horsepower
with a volt meter set to DC, pull the wires off of the starter solenoid coil (the small wires) and check for 8 - 12 volts DC at the wires when the key is turned. A poor connection at the solenoid coil will cause slow turning engine cranking or none at all.
If you have 8 - 12 volts there check for voltage to ground on the large cable that goes from the solenoid to the starter motor, one probe on the cable and the other on ground or ( - ) at the battery. Turn the key to start, if you have voltage to the starter motor but it does not turn loosen and retighten the mounting bolts to the starter motor and if that does not help do the same for the engine to ensure you have a good ground. If none of that works your starter motor needs to be replaced, if you have no voltage to the motor the solenoid or battery connections are faulty.
You can also quickly test starter health by conecting a set of jumper cables to a good battery, clamp the neg. to the engine block anywhere and tap the pos. to the starter cable connection from the starter solenoid, if the engine spins over your starter is healthy and the issue is certainly between the key switch and the starter solenoid.
Jul 07, 2014 | Briggs & Stratton Briggs Stratton Intek V...
The starter on the 12res Kohler generator just hums (spinning sound). It doesn't engage the flywheel. Do I need a new starter?
OC is over crank failed to start. It will normally try 3 times before giving this error. You need to disconnect the battery and remove the starter motor, make sure it is free to move / spin. Either the starter has seized or the engine has siezed. Make sure the engine is free to rotate also, once you remove the starter you will see the engine flywheel there, removing the spark plugs will make it easier to rotate the engine. I would guess it is more the starter.
Jan 06, 2014 | Kohler 12 kW Emergency Power System -...
Tractor will not turn over. Replaced solenoid. This 1964 Ford 4000 has been converted to a 12 volt. I have replaced broken wires and tested the key switch and strater button and battery tested good bu
use jumper cables and put power dirrect to the starter and see if the starter is any good next put power to the small terminal on the solenoid that small terminal triggers the solenoid a lot of times when these a converted to 12volt the starter doesn't get changed out til it fails and 6 volt starter are not happy with 12 volts
May 20, 2012 | Ford Garden
I go to turn the van on and all i get is a click, all lights come on and battery tested out fine. Tried jumping it didnt work, mechanic took a hammer to the starter still didnt work. Any advice will help...
If the battery cables and battery check out fine then test for 12 volts at the signal wire at the starter when the ingnition key is turned to start. If 12 volts is present then the starter is bad or the ground strap from the engine to chassis is not getting a good connection. You can test for the the ground by placing a jumper cable to the negative battery post and the engine.
No 12 volts when cranking? Then check relay or ignition switch.
You can apply 12 volts to the signal wire at the starter to verify it will turn.
Do the interior lights dim when the key is turned to start?
Aug 17, 2011 | 2005 Dodge Caravan
Honda EU3000is. 2 year old unit used by electric start at least 5 days a week. My gen has recently stopped staring by the electric start, it turns over but just not as strong as when new, what i mean by...
I have a 5 year old EU300is that would not start with or without the battery. I went through all the usual such as gas, plug, oil, etc. The battery showed 12 volts, however, when tested further it would not hold a load. I bought a new American made battery and now the unit runs fine.
Jan 29, 2011 | Honda 6370C - Parallel Power Kit For ...
It just clicks when i try to start it, wont turn over
ureCheck battery charge it should have 12 to 13 volts if it is fully charged.Check all electrical connections from battery to starter and ground wires. Check the solinoid ,it must make a good electrical connection internally to make the starter motor run.If you are getting at least 12 volts to the starter motor and it still wont turn the starter may be bad. Also be sure that the engine can be rotated normally.
Jun 10, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Battery-ok. new starter. safety switch ok. turn key it clicks. thats all. not turning flywheel.
Clean the cable ends real shiny,and the post on the battery.Have the battery load tested,the battery can have 12 volts,but not any amps,or few amps left in the battery.Also,a cable could be bad,use some jumper cables,just the negative one,and ground one end to the engine on a good metal ground,clamp the other end to the negative side of the battery,see if it will start,if it does,then the negative battery cable is bad.Also see if it will start by crossing out the solenoid on the fire wall.Small terminal to large terminal going to the starter.The small terminal will have a s on the solenoid.
Jan 28, 2010 | 1992 Ford Ranger
Car doesnt turn over just makes a thud like sound and just changed starter
Your problem could be Battery only has 10 volts and you need 12 volts,,, 2nd you might have a siezed engine or the wrong gearing on new starter motor
If you jump start with another car connect the jumper leads Red to feed on both cars and then earth cables if still wont turn over ,,,take starter motor out
and you will see the starter ring ,put a big screwdriver in and see if it will turn if no ,,, engine no good (sorry)
Oct 02, 2009 | 1996 Honda Accord
Kohler 12 kW Emergency Power System - 12RES-L Logo
293 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
