Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
My deep freezer wasn't working, I don't know how long, but all my food supply got soggy; anyways, I thought it was the ice clog up issue, I unplugged it and I air dried the ice and the pipe, it is all clean. when i plugged it back in it was still on the mode of deforsting, so I turned the regulator that was at the back. It sounded like it started, but after 2 or 3 minutes it stopped, now it sounds like water is running through. NEED HELP!!! PLEASE..is it broken?
  • 4,793 Answers
Let it run on auto defrost,then set temp to normal freeze,should be fine(keep the doors shut......)
Posted on Jun 03, 2010
Clogged ice maker
1, ice maker may need to be replace, 2 water line may be frozen , if so turn off the freezer to defrost it for few hours, 3. when was the last time to replace the water filter? make sure you replace it when the time expired.
Sep 16, 2013 | Sub-Zero Freezers
I have a 22 CUFT upright reach-in that ices up constantly. The ice builds up in the back of the freezer near the drain and then extends out to all the food toward the back area. I've tried increasing the...
this can be multiple issues. look for the freezer being level. look for any missing screws where water can leak out during defrost. make sure the door closes and seals. be sure you have the right amount of defrost cycles at the correct length. check to see if defrost heaters work. you may need to add a heater to the drain if there isn't one. worst case: remove product overnight and store in another freezer, unplug unit and leave door open to defrost, then plug in first thing in the morning.
Apr 17, 2017 | Arctic Air 22 cu. ft. / 623 liter Upright...
Food is unfrozen, but thermometer says temp is 28. We assumed at first that one of our kids didn't shut the door tight, but today the food is still soggy. Like I said, the temperature is 28, but the...
This is truely sad that you lost the food. Your temp gauge is definately not working it sounds like.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 06, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
My freezer doesn't seem to be freezing as well as it has in the past. somethings are frozen hard but ice cream isn't as solid as it should be
Try this... unplug...
take everything out and defrost the freezer
(go get a couple bags of ice and a big clean garbage can so you can keep the food cold)
you can defrost the freezer faster with a hair dryer
when you finish turn t'stat to high setting... put all food back in and dont overload and dont block any air vents (if they are located at top dont overlaod)
plugg in wait 24 hrs...
if you dont notice a difference let me know...
hope this was helpful
Mar 08, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Leeking water inside fridge from top
Defrost drain is clogged. This accessable thru the back wall of the freezer. Also depending on your model some also have removable Bottom floors of freezer that also get ice accumulation. When the defrost drain gets clogged water from the defrost cycle has no where to go so it stays and accumulates ice till eventually it leaks into the fresh food section. Clear the drain completly and you will have no more problems.
Feb 02, 2010 | Freezers
My Maytag side by side fridge freezer is leaking at the bottom and ice is collecting at the bottom of the freezer. I cannot find any model number but think it's about 6 years old
The drain is clogged behind the wall in the freezer you can do one of three things take the back wall inside the freezer off and thaw the drain in the bottom and clear it out,Pay someone else to do this,or you can mover your food for a day unplug the unit open the freezer door and leave it off for 24 hours allowing the ice to clear from the drain,seems to happen about every five or six years with Maytags..
Aug 12, 2009 | Maytag Freezers
DEEPFREEZER
The best you can do is ensure that the compressor area and fins are not clogged by dust and such. But don't mess around long, call a repair man to fix your freezer if cleaning doesn't help. Prob cheaper than replacing your spoiled food.
Oct 24, 2008 | Freezers
Ice built up on bottom of freezer then dripping down front
Probably a clogged drain. Use a pipe cleaner to unclog, then a turkey baster with hot water to clean out anything else. Then when the drain is clear, pour a weak bleach solution down the drain to kill the mold that probably caused the blockage If possible remove all food and let it sit unplugged for a day or two. This will clear some defrost problems.
Jun 22, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
275 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
