Question about Philips VR550 VHS VCR
Flicker on playback
My picture flickers when playing back tapes. I have tried new tapes but no change. Any ideas please?
  • 476 Answers
Could be tracking, dirty / faulty heads, or mis-alligned guide rollers.
First,adjust the tracking on the player during playback. This is done by pressing P+ or P- on the remote control.
If this doesn't work, use a video head cleaner. This consists of a video cassette and fluid. Follow the instructions with the cleaner.
If this still doesn't help, and you are confident in opening up the VR550, you could cleaner the heads manually.
Disconnect from the mains.
Remove the screws from the back and sides of the VCR.
Gently ease the lid off the machine.
Locate the large silver coloured head drum towards the back of the machine. There are four small receptors around the side of the drum. These are the video heads.
Take a small piece of clean white paper about 1.5 inches square. (Copier paper)
Hold the paper square over 1 finger and rub each head in turn. Keep the head near the centre of the paper so as not to catch the heads with the edges of the paper.
Check the paper for dirt from the heads.
Reconnect the player and try a tape. If the problem is still there, try cleaning again.
If none of this works, insert a tape NOT recorded on this machine (Mis-alligned rollers affect recording as well as playback) and play. Locate the rollers which guide the tape around the mechanism. Particulary either side of the head drum.
The rollers have adjustments on the top, which can be turned to move the guide up and down slightly. This is a fiddly job, and over adjustment could cause the tape edge to be damaged.
Adjust the rollers to get a clear picture. It is mainly trial and error.
If all fails then the video is probably destined for the skip.
If you need a replacement, www.cheapestelectrical.co.uk , will sell you a VR550 at a very good price.
Posted on Apr 11, 2008
I have a Pioneer PDP-R05FE 43'' TV. When I connect my PS3 to show Blue Ray films I get a flicker in the picture. It is connected using a good quality HDMI cable. There is no flicker when playing SD films...
go into your dispay menu and adjust the response 50-60hrz or if your tv is capped at 1080i then drop the ps3 to 720p and that will smooth it out alittle too as the interlaced picture is alittle choppy apposed to progressive picures and finally sometimes they just do it no rhyme or reason to it so dont go crazy about this ok :)
Jan 01, 2011 | Sony Playstation 3 (PS3) Console
Image flicker when viewing pictures in playback mode
You have the camera in Highlights mode.. while in playback use the up,down,right,left pad press it up and it will go through different displays like what settings you had the camera in when you took the picture then there is a graph screen... after that one is the highlights display which is what you have it on. Push up one more time to have it on regular playback mode. The manual explains this much better than I just did. If you have the manual you should check it out if my instructions dont help.
Mar 30, 2009 | Nikon D60 Digital Camera
CCD-TR705e Sony video recorder hi 8 playback 3 beams
the camcorder flickers when viewing playback - pictures flickering
Dec 10, 2008 | Pure Digital Point and Shoot Video...
Help!! No playback!!
First try a cleaning tape, if that doesnt work it most likely the tape path is out of alignment and you will have to send it in for repair.
Nov 17, 2008 | Panasonic PV-GS31 Mini DV Digital...
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
Bad playback
Please try to buy a head cleaning tape and put in your camera and play for three times..Then record a cassette and play,if you are not getting the picture replace the drum assy and check.
Oct 12, 2007 | JVC Cybercam GR-DVP9 Mini DV Digital...
Video playback
may still need to be cleaned andy.Sometimes cleaning tapes wont get the dirth out.This is more than likely what is wrong.How old is cleaning tape you tried may be time to try new cleaning tape,.
May 21, 2007 | Samsung VP-W70U Camcorder
Philips VR550 VHS VCR Logo
194 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
