Question about Ariete Cafe Retro Espresso Machine
The rubber grommet needs to be replaced - Ariete Cafe Retro Espresso Machine
  • 10,865 Answers
Hello. pop off a second one and take it to any good hardware store. These are common items. If the hardware store doesn't have it in stock they can order it in for you. J.
Posted on Jun 03, 2010
Rubber grommet in cox ride can it be repaired
rubber grommet on a cox ride on mower
should be able to buy a new replacement grommet
need to know the model
Nov 05, 2016 | Cars & Trucks
Motor drive grommet (black rubber)
Have you tried getting in touch with the manufacturer or any of their dealers?
Should you need -
HEADQUARTER
Elna International Corp. SA
icon_mail.gif Ch. du Champ-des-Filles 19
1228 Plan-les-Ouates
Switzerland
icon_mobile.gif +41 22 884 86 66
icon_printer.gif +41 22 794 95 40
icon_mail_back.gif info@elna.com
icon_home.gif http://www.elna.com/
You can also try getting in touch with dealers or country representative here.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 08, 2008 | Elna Heirloom Edition 6005
Tip
Removing GROMMETS safely!
Nothing worse than flapping sidecovers or loose parts on your motorcycle! Especially if you have ruined the rubber retaining grommet yourself.
Removing RUBBER grommets of any age without undue damage, can be achieved by heating the grommet from both sides (if possible).
Use a heat gun or even a handheld hairdryer with a nozzle, to heat the grommet to a temperature of about 50 degrees celsius or 125 Fahrenhiet or as hot as your fingers can hold comfortably.
Whilst hot, push BOTH edges of flange towards centre of hole until BOTH edges are clear of inner diameter of hole on the part. Push through to the clear side from this edge you have distorted inwards, working around in both directions simutaneously.
To replace them afterwards, submerge in hot water until hot and squeeze together from edges to form an oval. Insert an end into place and then feed each side in simultaneously. A light smear of liquid detergent will facilitate this, but is slippery on the fingers too. No need to use tools, they will detroy them! Cheers.
dc55502.jpgGrommets big and small, don't have to be cut or torn to get them off anymore!
on May 15, 2010 | Motorcycles
Replacement of cord for a 3.5 amp 1/2 in. Crafstman drill
that's surprising, as sears usually can solve those issues....anyways....you can just get num14 grounded wire, to length you need and that will cover the amps you're using for that drill and a bit more.you'll have to re-use the rubber grommets, or improvise one from something else....like perhaps a roll of soft rubber wrap made into a grommet!!!
Apr 22, 2012 | Craftsman Drills
Oil pressure sensor leaking on 02 pontiac grand am
get a new unit to replace it
safer , quicker and more reliable
Dec 05, 2017 | 2002 Pontiac Grand Am
How do you install a new windshield washer pump
the windshield washer motor is at the bottom of the reservoir,you will need to remove the water reservoir, the motor usually pull out of a rubber grommet & goes back in the same way, just make sure that the rubber grommet isn't perished, if it is replace it.......cheers
Jun 21, 2011 | 1998 Oldsmobile Intrigue
I need the rubber gasket that goes over the puncturer on my Kuerig coffe maker
I have the Keurig B-40. It is about 3 years old. Lost the Rubber Grommet. Went to Lowes and picked up a 7/16 OD x 3/16 ID Rubber Grommet for $1.27 ~ Problem Solved.
Aug 07, 2010 | Coffee Makers & Espresso Machines
I have an RSVP stainless steel knock box and need to replace the rubber sleeve and grommets on the bar. Where can I buy these. The shop where I purchased the box does not stock them. Thanks Al
Hi Al:
Ok, here's what the pros do.
Sleeve-- get a 1-2 foot length of reinforced rubber tubing/hose. Measure the diameter of the inner bar, get the right Inside Diameter on the tubing, cut the right length and slip over the bar-- if the fit is tight, you may need a drop of dish soap to slide it. Lasts for years, much better than the old sleeve.
Grommets. Look at an auto supply store for auto wiring grommets. http://www.autowiringsolutions.com/search.php is a good place to start. Buy a dozen of 'em, and replace them when they split :-)
Nov 29, 2009 | RSVP Espresso Knock Box with Tamp Station...
Lost rubber grommet in brew basket need replacement
You can order a new brew basket with grommet directly from Cuisinart - I would call them directly, but you can also order from their website - www.cuisinart.com
Jan 21, 2009 | Cuisinart DTC-975 Coffee Maker
Brake Lights do not go out
on ur brake pedal there is a rubber grommet on the pedal that hits a switch see if the grommet is missing if so replace the grommet
Jun 22, 2008 | 1993 Toyota Corolla
Ariete Cafe Retro Espresso Machine Logo
319 people viewed this question
Top Ariete Coffee Makers & Espresso Machines Experts
Tom Chichester
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Ariete Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
