Question about Drive Medical Daytona 4-Wheel Power Scooter - Red
Backup Beeper Can you disengage the backup beeper on this scooter? If so how do you do it?
  • 177 Answers
Hi. A lot of scooters use the same beeper for reversing and for the horn. The quickest way to disable the horn is to unplug the speaker or beeper from the circuit board in the top of the tiller where the controls are. If you ever need to make it work again in the future, its a simple matter to reconnect it. If you still need to use a horn, buy a cheapie one from the bicycle store.
Good luck. Neil.
Posted on Jun 03, 2010
How can I disable the backup beeper on an excel yoga mobility scooter?
99% of the time this is done thru a programmer. but you can try disconnecting your horn (if any) located at the front top tiller mechanism.
Aug 14, 2016 | Health & Beauty
I have undone the casing but not sure what wire to cut scared in case I do more damage lol
and the mobility scooter is ?
Regards
Rob
www.gewizrepairs.co.uk
Apr 01, 2015 | Health & Beauty
Can you remove the reverse beep
Best way is to locate the beeper. There should be two wires coming from it. You can clip the wire and insulate the cut end. Best to cut the red wire if one is there, as it will be the power lead. If you sell the unit later, you can restore the beeper.
Apr 01, 2015 | Rascal 600 T Electric Scooter w Seat Lift...
How do i remove or disconnect the beeper on my pride mobility go go sport scooter? I have the manual and it's worthless - i need instructions how to do it - i repeat - pride mobility manuals are wort
hi ,turning the scooter off will render the scooter inactive... sounds like a smoke alarm needing a battery replaced...
Regards
Rob
Dec 28, 2014 | Pride Go-Go Sport 4-Wheel
How do i disconnect or remove the beeper from my pride mobility go go sport 4-wheel scooter?
You can't disconnect a safety feature incorporated in the scooter. Beepers are there as a warning to things like low battery or not brakes, etc.
How do i permanently stop the beeper on my pride mobility Go Go Sport 4-wheel scooter?
That cannot be done because it is a safety feature of the scooter. If you're saying that it beeps continuously because of the flat battery, that indicates the battery may not hold its full charge and need replacement. if you remove the beeper you will not be notified when it's time to charge the battery. When the battery is charged, does it discharge faster than when the scooter was new? If so, then you need a new battery. Replace it and see if the beeper stops. If the existing battery is fully charged, does the beeper stop? If so, all is well, it's the battery issue. If it doesn't stop beeping, you have to take the scooter to an authorized agent to rectify the problem. I believe the battery is reaching end of its life.
Disconnect backup beeper
hi, IT's located underneath the scooter, it a small circular bleeper....it's normally located within a black plastic sleeve, just tape up the ends , that should quieten it down.
But take care when doing this as the cable cab be easily damaged...
Regards
Rob
Nov 22, 2013 | Shoprider SCOOTIE Scootie Jr Scooter
How to disconnect the back-up sound oon a medical drive falcon 4
Hi. On most scooters, the reverse beeper and the horn beeper noises are emitted from the same speaker.
The simplest way, is to unplug the speaker from the circuit board, although this might also disable the horn. It is easy to reconnect the beeper if you need to.
If you still need to use a horn, you can get cheap plastic ones from the bicycle shops.
Good luck. Neil.
Jun 11, 2010 | Drive Medical Drive Falcon 4 Wheel Compact...
Beeper sounds as soon asyou press forward or reverse will not drive brake engaged tthis is the same sound if you tried to move with the brake disengaged.
This could be the break micro switch or the wiring in the motor brake loom. check all connections in this area. You do not say what make or model this is ? !
Dec 09, 2009 | Electric Mobility Shoprider Electric Power...
Toyota prius beeper
you cant eliminate beeper yourself but if you taake it to the dealer it being so new they have to hook up the scan tool to turn of your beeper as long as its as factory system i work at a toyota dealer and we do this for cust a lot our computer has all the options in you car that are changeable due to the cust preference hope this helps
Mar 23, 2009 | 2009 Toyota Prius
Drive Medical Daytona 4-Wheel Power Scooter - Red Logo
556 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
