Question about Hotpoint Aquarius WMA42 Front Load Washer
Flooded the kitchen, spinning but not pumping out water
    Brigadier General:
  • 4,090 Answers
Usually an indication that something is caught in the pump inlet. You will have to remove the hoses and see if its a sock or some other small treasure..
Please rate my help++++Thanks for using FIXYA
Posted on Jun 03, 2010
Water flooded kitchen from pump help
then you will need to look and find where it is leaking from and seal it up or replace the part thats leaking.
Dec 09, 2016 | Dishwashers
Dishwasher pumping water but not dishwasher not in use
what is your model number is then we can get started then okay
Nov 25, 2012 | Dishwashers
My machine will not finish a cycle and just stays filled with water.
It sounds as though you either have a clog in the drainage system of the machine, or a bad drain pump.
May 06, 2012 | Hotpoint Washing Machines
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
On spin cycle the water wouldnt stop runninng in even when i shut it off.flooded my kitchen.it filled up and the door flew open.
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.You need to replace the water inlet valve with this part.
Dec 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer is washi, spinning and so on but it is not draining,,,,,, same water for all cycles. It stops when it is doen but there is still a tub full of water...... I tried the lid switch trick that did...
new pump or blocked take the waste pipe of and see if water comes out take out side first or you kitchen will be flooded lol don't forget you are dealing with eleci please be aware
Dec 07, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
Feb 07, 2009 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Hotpoint Aquarius WMA42 Front Load Washer Logo
207 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
