Computer will not Power up. Have new Power source which kicks off as soon as I turn computer on
  • 942 Answers
Hi kaasea, I understand that you are having a problem with your laptop turning it on. Try this suggested steps:
Make sure you have powered off the pc.
Remove the cable connected to the power source/
Remove the battery which is situated at the back of your laptop.
Press and hold the power button for 10 seconds. This will allow the laptop to reset its circuitry.
Reinsert the battery then the cable connected to the power source.
Turn on the laptop. If it does not, possible scenarios might occur.
The power supply on the laptop, CMOS battery, or the motherboard itself , whichever fails are the ones that is not functioning.
What other steps you can do is to reseat the power supply and then check the lights on the keyboard when you turn on the power button on your laptop. If there is no light on the keyboard when turning it on, most likely the power supply or the motherboard failed.
I strongly suggest to contact your pc manufacturer for possible repair if symptom persist...
Posted on Jun 03, 2010
Communications error between Windows 8.1 computer and Artisan 835 scanner
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
Source : EPSON support
Feb 13, 2014 | Epson Artisan 835 Wireless All-in-One...
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
Computer wont start
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB.
If same problem persist, boot from safe mode. Here's how;
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected, not Repair Your Computer
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would
If same problem persist, try reloading the Vista again.
Hope this works.
Mar 15, 2011 | Microsoft Windows Vista Home Premium...
Brand new computer-keyboard does not work
Have nice day :)
Mar 13, 2011 | ASUS 90-A4C1K1000 Keyboard
I have just installed the scanner and software, however, when i try yto scan an error message comes up saying 'the action cannot be completed because the other program is busy. Choose switch to to activate...
Might as well try to power cycle the device meaning disconnect it from the computer , turn off the scanner , unplugged the adapter from the power source and then push on the power button for 5sec so that excess power will be drain and then restart the computer also as soon as your computer boots up connect the scanner .
ERNZ
Feb 03, 2010 | Fujitsu fi-5120C
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
NISSAN 240SX A/C PROBLEM.
HI,
Yeah have the voltage to the compressor checked!..By turning on the A/C when hot (and not working),Add a test wire to the 12v output of the A/C relay, to "boost" the 12v amps/voltage going to the compressor clutch. As soon as the test wire touches a strong 12v source, the clutch immediately kicks in. Remember that 12v already existed on that wire, but a stronger 12v source helped give the clutch the extra kick it needs. Thank you!!..Hope this helps you out buddy!!.. :)
Jul 19, 2008 | 1993 Nissan 240SX
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
