Question about Canon Rebel XT / EOS 350D Digital Camera
I think I have broken a CF pin as my camera wont switch on
    Brigadier General:
  • 4,090 Answers
Well this is major camera surgery if you have
Please rate my help++++Thanks for using FIXYA
Posted on Jun 03, 2010
I took my CF card out to get photos, went to put it back in and the screen read "There is a problem with CF card. Replace the CF card." I didn't think there was a problem with the card. But I replaced...
Your CF pins in the camera are most likely bent/broken. This is a very common problem. Most repair shops will charge $150-$200 to repair this.
Hope this helps.
Wes
Sep 10, 2010 | Canon Rebel XT / EOS 350D Digital Camera
My canon xt rebel says err cf and wont do anything i bought a new one an the same thing whats wrong
One of more of the CF pins inside your camera are bent over. This is very common. The solution is to remove the main circuit and replace the bent/broken pins. Most repair shops will charge between $150-$200 to fix this.
Wes
Sep 05, 2010 | Canon Rebel XT / EOS 350D Digital Camera
MY MEMORY CARDS NO LONGER WORK IN MY SONY DSLR A100 CAMERA?
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.
Best regards - Michael
Jan 12, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
CF Card not found
Ok here is the issues with the Canon 300D digital Rebel XT model of camera. First issue bent pins or broken pins the CF card reader on this camera is Surface mounted soildered onto the bottom half of the mainboard a large ammount of disasimboly is required. After removing the mainboard next you need is a desolder rework station. to carefully remove the CF card reader from the mainboard one messup and it might be easier to replace the mainboard. Sometimes. next issue is the power issue if you have no bent pins or missing pins, and the battery door is pushing on the door closure switch and the memory card door is pusting on its door closure switch then most likely you issue is 1 of 3 fuses underneath the power switch. these switches are the size of a few grains of salt very very small.I charge 150.00 to change the fuses and 225.00 to replace the CF card reader as long as none of the traces are damaged. if they are damaged the main board would need to be replaced and it is around 250.00 + depending on the parts cost at the time. If your good at soldering go for it. if not then let the experts do it.
Dec 22, 2008 | Canon Digital Rebel / EOS-300D Digital...
My camera won't turn on. i've tried switching batteries, but that's not the problem. can you give me an idea of what's wrong?
Sep 02, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon rebel xti says cf card replace i have replaced same fault
Check with a magnifier and a flashlight the conditions of the CF memory reader pins. Usually this kind of cameras have the common problem of have bent or broken the CF reader pins. This may caused the original CF error. If you tried to format a CF memory card, then the bent or broken pins may caused the Error 99. By the way, error 99 is applicable to a very open range of problems (lens contacts, faulty shutter, CF memory card access errors, etc). If is under warranty your camera, once you confirm the reason of the problem, send it to Canon for repair. If is out of warranty, you need somebody to repair it, which is not easy for the common person. If need help on repairing it, please contact the ID user Great_items_2004 at ebay. Regards and good luck.
Jul 08, 2008 | Cameras
"no CF card"
try reformatting the card. otherwise you either have a defect in the card that does not manifest itself while not in the camera, or you have a broken pin in the cf slot. look down it to see if all the pins are upright and none missing. next, you can try another cf card. if you get the same reading then its the camera.
reset the camera by removing the main battery and reinstalling it. if that does not work, then you will likely need to send the camera for repairs. if you have broken or missing pins, it will also occasion a repair shop visit.
good luck
mark
Dec 24, 2007 | Canon Digital Rebel / EOS-300D Digital...
Digital rebel EOS ds6041
This happens when image data cannot be written/extracted on CF card. Try a card that you know is ok ( works on other cameras ). If problem persists one or more pins in the CF card chamber may be bent or even broken off. Try to straighten but be careful not to damage undamaged pins... but may have to go to an expert for repairs.
Sep 13, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon Digital rebel Wont turn ON
This happened to me today. The lens drive sounded weird - like off gear. Then it froze and wouldn't turn off without taking out the batteries. Then, it would turn on. Now it's ok. What I did was remove the cf card, lens, regular battery, and the little battery that is also in the battery compartment. I let it all sit while I did other things. When I put it all back together it turned on and I had to set the date but everything worked fine.
Sep 02, 2007 | Casio Exilim EX-V7 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
108 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
