Question about Transparent French TV Commercials, Volume 3 (with Dialogs) (FE851DCD)
Extreme fluctuation of TV sound leval drives me nuts!!!!
Half of my movie is whisper like, other half is BLASTING the paint
of my walls.
Is there a device that would keep the TV sound leval?
And please don't tell me anything about Terk VR-1, that is for analog tv.
Thanks.
    Brigadier General:
  • 4,090 Answers
Arn't all french movies in whisper and dark screen mode?
I suggest using an amplifier ( yes an amp) reduce the volume on TV to just audible and plug in xtension line to an amp and set the volume on it. It is probably a faulty sound board in your unit. The use of an external amp will control it better by the audio out line.
Please rate my help++++Thanks for using FIXYA
Posted on Jun 03, 2010
Im wanting to paint my out of house like the trim but i have car paint that i mixed half house paint and half car paint will that matter
Yes, it matters while this is not suitable to go with. Because it will not mix perfectly that you can go for either your house or your car.
im-wanting-paint-out-house-like-trim-but-i0bi5i5c5y5upqwvylbf2zfm-1-0.jpg Oil Color Paint:
Da Vinci Artists Oil Color Paint Display
May 05, 2015 | Tools & Hardware - Others
Oil comes with discharge air
Piston rings may be broken or cylinder bore scored. These will allow oil to pass at a fast enough rate to cause problems for painting or media blasting, but slow enough to not register on sight glass or filler plug.
Feb 02, 2012 | Air Tools & Compressors
I was only getting the bottom half of printed words. Ran test pages, alignment, clean printheads. These inks are brand new. It also did it with my other inks which is why I replaced them. I have Kodak...
Cleaning the print-heads is the correct action to take -- if the ink-jets are clogged, then the ink (in either old or new cartridges) cannot be sprayed onto the paper.
Note that the print-head has multiple jets -- like painting across a wall with a wide paint-brush.
So, if you don't have paint on the top half of the brush, then only the bottom half of each row on the wall will get painted.
Try some more head-cleaning cycles.
Jun 25, 2011 | Kodak ESP 5 Printer
Printer creates horizontal lines across paper that are either blank (no ink) or skipping/sliding looking blurring and distorting the text in that spot. This has been going on for a month. Changing...
The print-head is like a paint-brush -- brush sideways across a white-coloured wall, and you should get a wide "band" of paint. If only half of the paint-brush has paint on it, then only half of that "band" on the wall will get painted, leaving a horizontal strip of white showing through.
So, launch the Canon software that is installed on your computer, and run a few "print-head-cleaning" cycles, to unclog those ink-jets that are _NOT_ shooting the ink onto the paper.
May 20, 2011 | Canon PIXMA MP780 All-In-One InkJet...
WHEN IT PRINTS IT IS SKIPPING LINES
The ink-jets are like a wide paint-brush, painting a "band" across the page.
If half of those ink-jets are clogged, or only half of the paint-brush has paint,
then only half of the "band" will be "painted" onto the surface.
So, run a few "print-head-cleaning" cycles, to try to UNCLOG those jets.
Feb 24, 2011 | Canon PIXMA MP780 All-In-One InkJet...
My LG BD530 Blue Ray dvd player /usb will accept my 16GB flash drive to view movies as it has a usb plug in. It will not let me play the same movies from my Western Digital 750GB external hard drive. When...
Could very well be that the external hard drive is drawing more power than what the player can deliver - it is enough for a usb stick but not for the external drive. Now if you use an external drive that is self powered I am sure there will be no issue.
Mar 27, 2017 | Televison & Video
Adjustment of a Chamberlain WD822KL
The opener is having a hard time operating the door. It sounds like the door is out of balance. The door should stay all the way up at half down and all the way down. You should be able to raise and lower the door by hand EASILY. The opener is only meant to lift10-15 lbs. Thanks BB
Apr 08, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Video capture problem
i m having pixelview tv tuner card since last 4 years and i just use to watch tv occasionaly last week when i was watching a movie i tried to capture it i was amazed to see that just one minute movie had 700 mb of space in my hard disc it is saving the film in avi format is there any solution so that it starts capturing in mpeg format becouse i dont have much space in my hard drive to capture half an hour movie like this please help me out
Aug 29, 2008 | Prolink PixelView PlayTVpro Video Capture
Half a screen
The picture on your TV screen is driven from the center to the top and bottom of the screen by the vertical drive circuit. The fact that you can see the entire picture means you have a problem called foldover. This is caused by a failure in the vertical drive circuit where the vertical saw signal is altered by a component failure within the vertical drive circuit. You cannot solve this problem but any good repair shop should be able to correct the problem at a reasonable cost.
Jun 22, 2006 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Computers & Internet Logo
100 people viewed this question
Top Transparent Computers & Internet Experts
k24674
Rose li
Rose li
Are you a Transparent Computer and Internet Expert? Answer questions, earn points and help others
