Question about Mackie 1202vlz3 12 Channel Mixer
Is it possible to get a mackie audio transformer for a 1202 original mixer that has an input of 220 volts instead of 110v? Own a couple of them and they are great. If so, what size is the transformer. Thx in advance.
4 Suggested Answers
young red
  • 3 Answers
SOURCE: bad transormer in my Mackie 1202 20 watt mixer
how u hook up a mixer
Posted on Jul 31, 2009
rexark
  • 55 Answers
SOURCE: hook up audio ut to audio in from mixer to computer
You just need a USB audio interface ... the outputs from your mixer are analog, which will plug into the right/left inputs on the audio interface ... and the audio interface connects to the computer via USB ... this is a very common way to do it ...
There are a lot of devices out there ... I'm using a Tapco Link.USB audio interface ... not too expensive ... you don't need anything fancy ...
Once you get the USB audio interface (by the way, if you are using a Mac you probably do not need to install any software for it) then you want to make sure your audio inputs are set to use it ... there are two ways to do this .. first way is right in the Cooledit software, if there is a place to tell the software what the input audio device is ... if this is not possible then change your systems general audio settings to select the USB audio interface for sound input.
That's it!
For audio expertise with conference recording and presentation and help with PA system problems, visit www.rexark.com
Posted on Mar 06, 2010
SOURCE: hook up mackie mixer to m-audio fast pro
111111111111111111111111111111111
Posted on Dec 08, 2011
Need a power transformer for a Mackie 1202-VLZ mixer
The transformer itself will have the codes you need to replace it either printed on it or on a label stuck to it. Mouser should have what you need.
Sep 16, 2014 | Music
Hello, I have a Mackie 1604 VLZ Pro from 1995. It's 110 volts and I want to change it to 220 volts. Do I need to buy a new transformer? I don't want to us an external step-down...
The LEAST expensive thing to do is to buy an external stepdown transformer.
Here is a link:
http://www.world-import.com/transformers.htm
The 100 Watt would be adequate... If you think you might need more you could have a reserve for other equipment... At around $8 USD I don't think you can beat that. The labor cost to change the internal transformer would cost many times what the external transformer costs, not to mention the cost on a new internal transformer.
Jul 24, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
How do i setup my mackie 1202
Please view videos on YouTube. Search for "mixer setup". There are a bunch, and the information and techniqes are the same for almost any of the analog mixers. You might refine the search to Mackie mixers.
Mar 17, 2011 | Mackie Music
I need a new mains transformer for my Mackie 1402vlz3 mixer but can't locate on in the UK. NB 1402vlz, not 1202 vlz as per the product below. (Can't get 1402 on the categories). Where can I source one, or...
Your best bet is to contact Mackie directly for a distributor in the UK.
The contact information is listed below.
Dan
LOUD Technologies Europe PLC GENERAL CONTACT Unit 1 Century Point, Halifax Road. Cressex Business Park
High Wycombe, BUCKS, HP12 3SL, UK
Phone: + 44 (0) 1494 557 398
SALES Email: eusales@loudtechinc.com
SERVICE Email: euservice@loudtechinc.com
Aug 20, 2010 | Mackie 1202vlz3 12 Channel Mixer
Type pf op amp in a Behringer XENYX 1204USB Mixer and a Mackie - 1202-VLZ3
Behringer uses 4580's in appropriate packaging everywhere. There are 339 comparators for the level indicator area.
The Mackies uses both NJM2068 and NJM4560M
The 2068' are used in most of the low noise areas and the 4560 is used in the 75Hz high pass filter for example.
Jul 22, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Sir, while ago i sent a message to you regarding my 1202-vlz3 mixer (mackie) i to know how much the secondary voltage supply ?? thanks and god bless
The schematics don't show this, however reverse engineering this there are two windings... one is for the phantom power of 48 VDC... this winding needs to provide about 55 to 60 volts DC to the 48 volt regulator. EXPECT around 40 to 50 volts AC on this winding to the full wave bridge of D1,2,3,8.
The +/- 16 volt power regulated by LM317 and LM337 regulators will likely require about 20 volts DC into the regulators. It will be less than 25 volts because there is a 25 volt cap filtering.
Given a 20 volt DC from the diodes D5,6 and diodes D4,7 the transformer will be around 15 VAC either side of the centertap.
A minimum would be 12.5 VAC and say 18 VAC either side of center.
You should see near pure DC across C1 and C2 with only a little ripple of 2 volts MAX. The ripple should be 120 Hz. An oscilloscope is your friend in this area !!!
Jun 16, 2010 | Mackie 1202vlz3 12 Channel Mixer
Computer->M-Audio-FastTrackPro USB->trs outputs 1/2->linein 11-12 of mackie 1202-vlz3. How can i get stereo sound out of the mackie?
Use TRS to TRS balanced cables from the M Audio to the line in 11 and 12.
Set the pan controls for the 11 and 12 to opposite directions to split the stereo to left and right main outputs. (otherwise both main outs mix the left and right and you get mono result.
Feb 05, 2010 | Mackie 1202vlz3 12 Channel Mixer
Mackie 1202vlz3 12 Channel Mixer Logo
161 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
 Grubhead
Grubhead
Are you a Mackie Music Expert? Answer questions, earn points and help others
