Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Ice maker not working
The ice maker on my lg french door bottom freezer has stopped working. I can see water in the tube trays but it is not freezing. There has also been water leaking from the ice bucket. It seems that the ice maker isn't staying cold. HELP!
  • 776 Answers
TO see the diagnostic test please refer to the below link and on page 27 you will find some test to be done to diagnose the issue:
http://docs.google.com/fileview?id=0B5If-wTgYWH5NGY3M2JhMGYtYWIzYi00NWJhLWEwNzEtMmFiOTk0YzQxMDlm&hl=en&pli=1
Posted on Jun 03, 2010
  • Dushyant Bist
    Dushyant Bist Jun 03, 2010
    Ok,
    I would like to add on that in your case what i am suspecting is that your icemaker fan motor may not be running to push air up from the freezer into the icemaker compartment.
    Please proceed with removing everything in the freezer and remove the back panel inside the freezer, the icemaker fan is in the back upper left corner. If it's not running then you will want to replace it.
Was useing the water....then the door alarm came on and now the water and ice maker is not working
try this ,in the back of freezer there is a tube that feeds ice maker sometimes it freezes up aim a hair dryer at the tube for 5 to 10 mins ,not to close or it will melt
Apr 13, 2013 | Maytag MFI2266AES Stainless Steel Bottom...
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
Kenmore trio won't make ice
my ice maker won't make ice and sounds like trying to run water into it but isn't filling it up
Sep 11, 2009 | Kenmore 24.8 cu. ft. Trio French Door...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Icemaker won't fill tray,
Was the inlet tube frozen. If so your water inlet valve on the back where the water supply comes in is probably leaking and when the water reaches the freezer it freezes, blocking the inlet tube. Replace the water inlet valve.
You can Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Samsung RS2630WW Side by Side Refrigerator
Ice maker wont make ice
CHANGE THE FREEZER TEMP TO -2 AND THE REFRIGERATOR TEMP TO 44 AND IT WILL START MAKING ICE AGAIN
Nov 25, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Water freezing on the tray section under the freezer drawer.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 15, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Aug 15, 2007 | LG LRFD25850 French Door Refrigerator
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
247 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
