Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Bosch SHU9925UC Dishwasher Stuck in Ini...
By dcomfort on Apr 09, 2008
When dishwasher is started the initial drain cycle comes on. It drains any remaining water in tub, but then drain pump just stays on and never moves into fill cycle.
I read your solution to another Bosch model. I removed the inlet valve to vacuum out any water from the underpan from a "flood" problem. The pan was bone dry. I also had checked and cleaned the drain and impellers to be sure they were clear. I also tried to cancel the cyle buttons and restart.
None of these actions solved anything. I am going to test the inlet valve solenoid and check the intake filter today. I saw that checking for a stuck float may also be a problem, but I am not sure where it is. When I look back behind the inlet valve with a flashlight, I can see a small styrofoam looking donut, but it is sitting flat on the bottom.
Comments:
Apr 09, 2008
- I read on appliancepartpros.com blog how someone took off their side panel; the two torx screws inside front rubber door seal. I was then able to get to everything below. The drain pan was dry, but I jigged the red float bar to the float switch a few times and it cycled out into the water fill cycle.
The dishwasher is starting to run. I'll observe the cycle and see if all goes well.
Same Problem
Apr 15, 2009
-   I HAVE A Bosch SHX46B05UCDishwasher which is Stuck in Initial Drain cycle.-   Guest
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
Buying a used dishwasher Maytag MDBTT70AWB anything I should know about this dishwasher
Answer
Water is splashing back at me when I hook up the Haier HDP18PA shy?
Answer
When pressing any front button on the control panel nothing will light up or start up in any... (More)
Answer
will not drain tried various cycles sink line is clear. Can it be a relay
Describe your Dishwashers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in , TX
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
