Question about Makita 5" Disc Sander GV5000
How to replace power cordon Makita GV5000 - Makita 5" Disc Sander GV5000
Can i bypass the switch on a makita skill saw
OMG, absolutely NOT!
I know a guy without 3 fingers due to one of those on a construction site. He said he never felt a thing.
Buy a new switch.
  • Makita Canada Inc. www.makita.ca Makita Canada: The best in class for cordless power tool technology. A leader in power tool technology for the professional.
  • Makita Saw Parts ' Great Selection ' Great Prices ... www.ereplacementparts.com/makita-saw-parts-c-97_98.html Fix your Makita Saw today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide shipping, no hassle returns.
  • images of makita saw parts bing.com/images th?id=oip.m79ac54922c7af758ce5909fe9cde9163o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m8226e4e7540d1403e6b34f0609fee8ado0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mc9c1b6c779ab4de644cda35842865ffbo0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mfb5ac75b7411568957f4d7028521f0b4o0&w=80&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mdd935730eb9fe8614bf23952794b8ca9o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.md1140885e7ec8b5124cabfe71fdb3085o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of makita saw parts
  • Makita Power Tool Parts - Makita Parts - eReplacementParts www.ereplacementparts.com/makita-parts-c-97.html We have the genuine Makita parts and tool repair help you need to get your power tools running like new again.
  • Makita Parts - Tool Replacement Parts ' Tool Parts Direct www.toolpartsdirect.com > Brands Makita Tool Parts - Shop Makita parts online at Tool Parts Direct. Over 38,000 Makita replacement parts and schematics available.
  • Related searches for makita saw parts
  • Makita Tool Parts :: Makita Saws - Tool Parts Canada ... www.toolpartscanada.com/makita-tool-parts/makita-saws-page-3.html Please choose your tool from Makita Benchtop line below view parts breakdown
  • Makita Saw Parts ' Sears PartsDirect www.searspartsdirect.com > All Brands > Makita Parts Shop the best selection of Makita saws repair parts and accessories at Sears PartsDirect. Find replacement parts for any Makita saws repair project.
  • Makita - Authorized Factory Service Centers www.makitatools.com/en-us/Modules/Service/ServiceCenters.aspx Makita Authorized Service Centers meet our high-quality ... Genuine quality Makita replacement parts; Most tools repaired within 3 days; Maximum Repair Cost Program;
  • Makita Saw Parts ' eBay 9k= www.ebay.com/bhp/makita-saw-parts Find great deals on eBay for Makita Saw Parts in Corded Circular Saws. Shop with confidence.
  • PARTS - Makita UK https://www.makitauk.com/shop/parts Parts . Ask Makita ' Find a dealer. Part search Search for tool drawing: Filter: 1 - 2 - 3 - 4 ... Contact Makita! 01908 211678. Monday - Friday 8am to 5:30pm.
  • Makita Tool Parts - Tool Parts Canada - Parts that makes ... www.toolpartscanada.com/makita-tool-parts.html Please Choose Makita category Below Which Matches Your Tool
  • Jun 20, 2016 | Makita Saws
    Makita miter saw wontr turn on
    make sure that your outlet is hot, once verfied that you have power going to the plug of the saw cord, verify that you dont have any breaks in the cord itself. once verified no issues with cord you can check for power at the switch, if there is power at the switch but not coming on, probably bad switch.
    Aug 10, 2014 | Makita 10" Miter Saw LS1030N
    My Makita circular power saw works then stops working, then starts again. Why is this happening?
    Things to check: With the saw running, safely grab the cord by the boot and pull and twist it around. This is where a break frequently occurs inside the cord and when the saw is held in certain positions the break will either open or close. If the cord's OK, unplug the saw and remove the brush caps and check the brushes. If the brushes are less than 1/4" long or the springs are burnt or broke they won't make good contact with the armature. If the cord & brushes are OK your next recourse is to replace the switch (Makita PN 651172-0).
    Jan 22, 2013 | Makita 7 1/4" Circular Saw 5007NB
    How do you get to the inside of a makita 4.5"
    there is a screw in the bottom of grinder next to the power cord, that's all you have to take.
    (althought I don't know the model of your grinder, the most of makita brands have the screw right there) good luck!
    Jul 02, 2011 | Makita Saws
    I have a makita 5997nb circular saw that i have had for 26 years with no problems. but now it will not power up. I think its the cord. How do I replace it myself?
    The cord ... or the switch ... or the brushes.
    You will have to take the handle apart to access the end of the cord and check the switch. Test your cord with the ohm function of a volt/ohm meter.
    Thanks for your question and good luck with your repair.
    Feb 06, 2011 | Makita 7 1/4" Circular Saw 5007NB
    Need new power cord for Makita sander. Looks very much like the Makita 9924DB. Where can I get this part? Live in Canada
    If you want the Makita cord for this tool it's part number 664026-2. It can be ordered through several online sites like www.ereplacementparts.com for about $22 +shipping. You can also use any 18-2 power cord (18 guage-2 leads) with the molded plug end on it, available at most repair shops and some retailers for about $10. Attaching it to the switch is easy, just mirror the old cord as far as how long each lead should be and how much wire to strip off.
    Nov 22, 2010 | Makita 9924DB Electric Sanders & Polishers
    Instructions or diagrams on how to replace a power cord for a makita circular saw.
    here's a article on how to fix it.
    http://www.amazines.com/Electronics/article_detail.cfm/78565?articleid=78565
    May 05, 2010 | Makita 7 1/4" Circular Saw 5007NB
    Makita gv5000 5" disc sander won't work
    there isn't an internal fuse. by the sounds of it you probably have a short, a bad brush, or some arcing.
    if you use your sander for fine sanding (100+ grit paper) you have to make sure to clean out the motor housing. Fine sanding dust, like any fine dust, creates alot of heat when aerated and can melt the plastic brush holders or can cause the electricity to arc from one wire to another inside the housing.
    my advice is to take the 8 (i think it's 8) screws out of the side of the gun and carefully pull the halves apart. there isnt alot you can mess up inside and just visually inspect the wires for burns or melting on the brush holder.
    here's a breakdown if you need it.
    http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_GV5000.pdf
    if you find something inside that you're not sure of, or if you have any additional info i'll keep checking in on this.
    Dec 08, 2008 | Makita 5" Disc Sander GV5000
    Makita 5" Disc Sander GV5000 Logo
    Top Makita Tools & Hardware - Others Experts
    Jim Thurston
    John Porter
    Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
