Question about SDI iHome iH4 Battery for Apple iPod
How to change the time setting from military time (24hrs) to regular time (12hr w/ am/pm)?
How to change from military time to regular time
use the mode setting to change from 24 hr to 12hr
Nov 14, 2016 | Military Time Watches
CHANGE FROM MILITARY TIME TO REGULAR
Hold down the MODE button until the time starts flashing. Then use the buttons to cycle through the time, date, and so forth until you see 24hr. On that menu tap the buttons you use to change the setting to cycle it to 12hr.
Feb 01, 2015 | Casio LA670WA-1 Wrist Watch
HOW TO FIX CLOCK THAT SHOWS MILITARY TIME ON RADIO
There could be a slider switch to go between 24hr and 12hr slide it accross. OR Hold down clock and see what that comes up with sometimes it can say AM/PM thats 12hr too.
Aug 01, 2013 | Bose Wave Radio
I want to change the time from military to regular, but my bose does not have clock set just and arrow to the right and left for time
The manual is available at Bose.com and page 17-18 shows the detail.
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
May 02, 2011 | Bose Wave Radio
I want to change from military time to regular time on my Bose wave radio. I already tried holding down the alarm set button and on/off button but it didn't work
Page 18
http://www.retrevo.com/support/Bose-Wave-radio-Radios-manual/id/525bh044/t/2/
Jan 27, 2011 | Bose Audio Players & Recorders
I wrote a few days ago and did not get a response. Please, how do I change my bose raio/cd time back to regular time. It just went to military time. I do have grandchildren maybe they did something. ...
Jan 24, 2011 | Bose Wave Radio
How to change 24hr to 12hr and time on a cg watch?
Got one too and just figured it out. Press MODE and hold it until numbers flash. Then press RESET until the hour is flashing. press START and for each time you press it the time advances by an hour. Notice that AM or PM shows. If the hour is in military time, pressing the start will advance from 01 thru 24, the next press will give you 01 and the AM shows. continue until 12 AM and the next press will be 01 PM and so on. When you get the setting you want, press MODE and you're ready.
May 02, 2010 | Watches
Military Time
Press the "function" button for a couple of seconds. The display will indicate 12hrs or 24hrs.
Use the minute or hour to change the setting for 12hrs and you'll have normal time again.
I hope this helps!
Feb 02, 2009 | Digital Products International Clok Smooth...
Bose Clock
To set AM/PM (12 hour) or Military (24 hour) time - With the system off, hold
down Alarm Setup and press On/Off to switch between AM/PM (12 hour) and Military
(24 hour) time formats.
Feb 18, 2008 | Bose Wave Radio
Getting the clock off military time
With the sytem off, hold down the Alarm Setup button and the On/Off button to switch between 12 hour (AM/PM) and 24 hour (Military) time. If you need the manual go to
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/music_system.jsp
Nov 28, 2007 | Bose Wave Radio
SDI iHome iH4 Battery for Apple iPod Logo
641 people viewed this question
Top SDI Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SDI Audio Player and Recorder Expert? Answer questions, earn points and help others
