Question about Toshiba Televison & Video
I have a dark line on the bottom of the tv seems like the verticle is going wrong How do I adjust the verticle toshiba cx 2779k
SOURCE: Toshiba CF36G40 36" TV Problem
IO board has bad solder joints or is bad if you tap the outside firmly it will come on for a while
Posted on Jul 22, 2008
  • 86 Answers
SOURCE: Verticle line down the middle of lcd monitor.
This is a common problem with LCD screens. It is pixel line damage and the screen is permanently damaged and is not repairable. It will probably get worse. The only answer is to replace it
Posted on Dec 09, 2008
  • 139 Answers
SOURCE: verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Posted on Mar 06, 2009
  • 231 Answers
SOURCE: LG REAR PROJECTION TV DARK SCREEN PROBLEM
very possible unit has bad optical engine .May not be worth repairing.Optical engine is complete unit that includes lamp,LCD panels, fans,optics and other parts.They come complete and cost about 3-6 hundred dollars ..thanks
Posted on Jul 30, 2009
  • 5 Answers
SOURCE: dark picture cannot be adjusted
try you contrast and brightness levels, if that doesnt work maybe your AV jacks arent all the way connected, check your connections on the back of the tv
Posted on Sep 09, 2009
HELLO SIR, MY 1981 CX 500 WILL NOT START, IT SEEMS TO BE THAT THE IGNITION SPARK IS COMING WHEN THE PISTON IS AT THE BOTTOM OF ITS STROKE AND NOT AT TOP DEAD CENTRE. NO ADJUSTMENT ? I AM...
Paul,
If both cylinders appear to fire when the pistons are at the bottom, could you possibly have the wires on the wrong cylinders?
Nov 25, 2010 | 1980 Honda CX 500 A
Hello..Toshiba 51HC85, 2005 model. Turn on TV and verticle wavy lines appear until TV is warmed up completely. After warm up the picture is great again. Any ideas?
I've had the same problem for about the last 6 months. My workaround which was to leave the tv on 24 7 and just turn off the TWC service box. But now the symptoms are vertical dark lines going all the way across screen. My guess is that it will cost more to fix than worth it. I paid @$2000 for it new in 2004. Technology has gotten better so I may just go out and get a Samsumg for considerably less and be way better off. None of Toshiba's products had done well for me. 2 laptops, 3 tvs, etc. have taught me this.
Sep 20, 2010 | Toshiba 51H83 51" Rear Projection...
Dark horizontal line scrolling up from bottom of screen
if you are using a cable box .. then disconnect everything that is feeding signals into the tv ... then get a signal from some other source (like off the air antenna or video camera) ... if the tv still has the dark lines then you have a bad primary filter capacitor in its power supply .. if it works ok off the air and only does it when the cable box is hooked up .. then the cable box has an open primary filter capacitor . ... the dark horizontal bars you see is ripple from the rectified AC power that is not properly filtered ... if the TVs verticle scan rate is 60 hz and the full wave rectified AC amounts to 120 hz ripple then you will see two dark bars across the picture ... since the two signals are not syncronized then they will slip in phase with respect to each other .. thus the constantly moving pattern ..
Apr 16, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Jul 30, 2009 | LG 62SX4D 62" Television
TV screen became a lot darker than normal.
Hi.
yeah, opened the front flap of the TV>menu> brightness> increase. Sorted. No problem.
ain't gonna bother asking any more questions on this forum..........no help at all .
cheers, Pat
Mar 30, 2009 | Toshiba Televison & Video
Oct 01, 2008 | Toshiba Satellite P30 P35 Series Notebook
Toshiba 35A44
check the verticle stage
electrolitic capacitors
and the verticle IC
Sep 04, 2008 | Toshiba 35A44 35" TV
Vertical lines
hair line cracks in motherbord on soldering jobs look all over re soilde rthem back togther nicely
Oct 31, 2007 | Toshiba 46H84 46" Rear Projection...
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Televison & Video Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
