Question about Mitsubishi WD-65732 65" Projection HDTV
How do you retieve the error codes? - Mitsubishi WD-65732 65" Projection HDTV
    Brigadier General:
  • 4,090 Answers
All Mitsubishi DLP Televisions have a built in Diagnostic Decoder to store the last fault in memory. This will help the Mitsubishi Technician determine what area or part defect could exsist due to your television not coming on or turning off by itself. In order to read the error code from the front panel lights, you need to know how to access this information if it is available.
Please remember not to unplug the tv from the power outlet because this will reset the error code. The television must be in the power off state or shut off state to retreive the code.
Error Code Operational Check
Note: The TV must be in “Shut Down” and not have been switched Off, to perform the Error Code Operational
Check.
Pressing the front panel “ACTIVITY” and “CHANNEL DOWN v” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The “TIMER LED” flashes denoting a two digit Error Code, or indicating no
problem has occurred since the last usage.
Note: The front panel buttons must be used, NOT those on the Remote Control. • The number of flashes indicates the value of the MSD (tens digit) of the Error Code. • The flashing then pauses for approximately 1/2 second. • The LED then flashes indicating the value of the LSD (ones digit) of the Error Code. • The Error Code is repeated a total of 5 times.
Example: If the Error Code is “23”, the LED will flash two times, pause, and then flash three times, then this will repeat itself for four more times before the blinking stops. If you forget the code, you can start all over again after the LEDs have stopped blinking. Just remember you are looking for a two digit code, denoted by a pause in the middle.
Example: You are watching Television and after 20 seconds it shuts off with no picture or sound. By pressing on the front panel the INPUT and MENU at the same time starts the Diagnostic Procedure, and the TIMER LED will then blink six times, and then a small pause, then six more times. This is an error code of 66, and will indicate to the Technician a defect in the lamp ignition circuitry. This will help us to order parts for the repairs without guess work.
In addition to the above code retrieval procedure- most new Mitsubishi LCD & DLP televisions have a built in Error Code Log or menu system. To access this feature the television has to be on and have a picture or blue screen to read this fault menu . To read this Error Log in the television you have to use the Mitsubishi remote control and follow this procedure: Press & release the Menu button, followed by 3564 on the remote control. You will see Lamp time, Code & Status. If an error has happened, please read the numbers indicated under Code to our service person or office staff. We can determine by these codes how to handle service on your unit.
Posted on Jun 03, 2010
The tv comes on for 1 second and turns off and the red lamp light is on
Posted on Oct 19, 2012
Im getting a 42 error code on my mits whats wrong with it
Posted on Sep 14, 2011
I lost my puk kode
Hello
The link below should be of assistance for recovering your PUK code.
Click HERE to navigate to page.
Please feel free to let me know if you need any further assistance.
Kind regards
Lock123
Feb 07, 2011 | Cell Phones
Trying to retieve the radiocode for the audi-concert in my 2000 audi tt
The majority of AUDI codes are very secure and can only be obtained from your Main AUDI Dealer or a Radio Decoding Service
Will NOT be available for free from anywhere on the Internet.
Jul 14, 2010 | Blaupunkt Car Audio & Video
How do u unlock 97 acura rl radio
you need a radio code which is a 5 digit code usually place in with your car/owners info booklet. if it is not there you will have to bring it to a acura dealership ..there is a way that they can retieve the code by finding the serial number of the radio , punching it into there system and accessing the code.
Mar 30, 2010 | 1997 Acura RL
I have a 15+ year old, dual tpe answering machine. how can i find out the retieval code #
Many times codes are standard like : 6 zeros, 1234, 12345, 123456.
You can also try to reset the answer machine and in this way reset the code. For this you need to take the power out and the battery out for over night and then try to access it again in the morning :O)
Hope that helps
IF NOT Then try to return here
Have a nice time over there
Please rate my answer
Jan 10, 2010 | Cell Phones
Flashing D drive light while driving? Does the car need oil?
if the light is flashing that means there is trouble code or codes set in the transmission control module.you need to get it to a shop were they can retieve these codes and fix the problem before you cause any further damage to your transmission by driving it in its current condition. it may be in limp mode.
Nov 26, 2009 | 2000 Honda Odyssey
I have a Sony-Cyber shot DSC-P72
It's a memory card error,You can try to take the memory out and retrieving them with your computer
May 13, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
2000 ford explorer ''check engine light''
This vehicle has the OBDII system and you can only retrieve codes on this with a scan tool. Some of your parts houses like Autozone will retieve them for you for free.
Mar 12, 2009 | 2000 Ford Explorer
Format error
If Duo Pro got hardware problem, then it can not be fixed and you can't retieve data on it. Regarding new memory stick, camera will check it and let you know about format it or not.
Jul 31, 2008 | Cameras
Mitsubishi WD-65732 65" Projection HDTV Logo
2,099 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
