I just repaired my AC port, Now my keyboard and left mouse button do not work on my laptop. If someone could direct me as to where on the board I would find the connections and how I would go about fixing them I would be most appreciative. Laptop is an Acer Aspire 5535-5452
  • 4,924 Answers
The connections are visible after you remove the keyboard..and they are actually ribbons in a plug ..to remove teh keyboard you have to first remove the hinges cover (2 inch wide lid that it is under the monitor top of the keyboard) remove it first from the back on inged (unclick) and after that from the F1 and f11 keys it has an accces point for a plastic flat instrument ..After removing this ..you look for any screws may hold the keyboard in place ..and slide it 2 cm towards the monitor ..and up..cause it is also snapped in clicks..and under you will have its ribbon ..and the ribbon from the pad...anyway if it is just a plug issue well if not probably will have to replace the ribbon connectors ..but I guess being in the same zone located and both behaving bizarre it may be a cause of a shock ..and just unplugged themselves..
Posted on Jun 03, 2010
Why is it my touch screen workks, but my fold out keyboard os locked and buttons are not working. the letter buttons. help please.
the touch screen is not connected the same as your keyboard the screen is direct hardware connected and youre keyboard and mouse are connected as bluetooth devices. you shoud have what is reffered to as a .dongle, which plugs into any comuter usb port, and talks to the keyboard and mouse. first check or replace the batteries inn both the mouse and the keyboard, then make to turn on the switch on the backside of the keyborad. Then push the button,connect, on the back of the dongle, and finally push the connect button on the bottomside of the mouse.The mouse and dongle should flash if they are talking to each other.
If you have an old keyboard and mouse that plug directly into the computer then they are hard wired directly to the motherboard by sockets. these are not repairable. but first go to start-botom left corner and click on the icon and go to control panel and select keyboard and rest all defaults such as keyboard language, rebbot and try again...my keyboard after installing defaults to french canada and i have to change to us otherwise my question mark becomes a french e. I hope this helps
Aug 30, 2014 | Computers & Internet
TOUCHPAD MOUSE ANS KEYBOARD NOT WORKING
Try these steps.. Click start button, type "mouse" on Search Programs and Files, click "mouse" under control panel. In mouse properties options....as you an see the touch pad driver tab? click it. Choose or click option button and you can enable the right and left click button. About the keyboard problem,,,,,go to device manager, right click the standard PS/2 keyboard..uninstall it. Windows restarting and the keyboard driver will re install automatically.. check if the keyboard works fine.
Aug 17, 2014 | Acer Aspire 3810T 4810T 5810T
I have Dell laptop and the buttons on the touchpad sopped working
I would just install a usb mouse through one of you usb ports
Option 2 is to spend a lot of money to have both switches cleand/repaired
Nov 21, 2009 | Dell F3534 Touchpad
Re toshiba techra 8000
Some laptops have a touch pad between the keyboard and the edge of the laptop. This works like a mouse except you slide your finger around the pad to move the mouse pointer and the buttons next to the touch pad are the left and right buttons.
Other laptops have a small round button in the middle of the keyboard which is a mini joystick and it is used to move the mouse pointer around, it will have a couple of mouse buttons at the botom edge of the keyboard.
You can connect a normal mouse to your laptop, it is mush easier than using the laptop's touch pad or mini joystick.
Sep 16, 2009 | Toshiba PA3121U - Satellite Pro 6000,...
Touchpad will not work
Hello, seems like a problem with the touchpad, first disable and enable the touchpad with the button which is located at the top of the touchpad, the corresponding LED should change from blue to orange and vice versa. If this doesn't solve the issue, reinstall the driver for the touchpad, you can find this by searching for 'recovery manager' in the start bar. Next step is to select 'advance options' and choose reïnstall hardware driver, there should be an option called 'Synaptics touchpad driver' select and install. kr Gijs
Sep 10, 2009 | Compaq Presario CQ60-220US PC Laptop
IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Jun 02, 2009 | IBM Optical Travel Mouse 2224P0480
My wireless mouse and keyboard have not been working lately. i use the on screen keyboard and use a wired mouse temporarily. can anyone telll me how to fix both the wireless mouse and keyboard? Also the...
Check the batteries first to ensure they are good. Do you have a receiver and is it plugged into the USB port?
You probably already know how to reset/connect the Keyboard and Mouse.
But here is info to help if you are not sure how to do it.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jun 30, 2008 | HP Multimedia Cordless Keyboard/Mouse...
Left click for mouse does not respond - right click very slow
replace the keyboard with one from eBay that would be the least costly way to repair the problem. sounds like the cable has been damaged for the keyboard to motherboard interface. have you tried connecting a mouse to the usb port or the ps2 port on the back? that may solve the problem if you don't want to replace the keyboard
Apr 24, 2008 | IBM ThinkPad T40 2373 Notebook
IBM Optical Mouse doesn't work
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Nov 11, 2007 | IBM Optical Travel Mouse 2224P0480
Logitech wireless mouse
Nov 05, 2007 | Computers & Internet
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
