Question about Nokia 2610 Cellular Phone
Sim card rejected
My phone says sim card rejected. It is the sim card that came with the phone. Good evening sir, my mobile create a problem in which it display on the screen is sim card rejected.
  • 11 more comments
  • raj parmar Apr 09, 2008
    sir
    my network is not on and the network is idea cellular.
  • joy090394 Jun 27, 2008
    my sim card is rejected.i want to fix it without using any money
  • piratequeen1 Jul 03, 2008
    my sim card is saying its rejected. it happened after I tried to change my security password. any suggestions? its a net 10 phone
  • JakeThompson Jul 16, 2008
    after i tryed changeing my pass code it started saying sms card rejected?
  • Nanthu008 Aug 02, 2008
    I was scanning my SIM by Super Sim Scanner a msg appear that .... ur sim blocked. I checked it up bt it didn't work. What can i do....?
    Plz suggest me a solution as soon as posible.....
    Thanking You
  • nanny02 Aug 16, 2008
    my 2610 nokia phone screen says sim card rejected................. how do i fix the problem.????????????
  • manly man Sep 02, 2008
    i entered the PUK code incorrectly too many times and now my Phone tells me that the Sim card is rejected. i am under 18, my Dad is the bill payer and i need to unlock my phone as quickly as possible. i have a N73 Nokia. can anyone help me????????????
  • Anonymous Nov 06, 2008
    sir what is the best solution if you have a sim card rejected.
  • Anonymous Nov 28, 2008
    i have the same problem
  • aggressive_a Jan 15, 2009
    i am using a nokia 3110 callsic phone.When i tried to change the security no. it said enter a code i enter the code but it did not respond .Then it said final time then again i wrote the same code but it did not work.now it says that the "sim card rejected. now what should i do ?????????????witout spending much money
  • adian May 02, 2009
    i was playing with the secruity and know the screen says PUK Disabled Card Blocked
  • dgasper26 May 17, 2009
    I was just testing the phone out and then it said put your pin so i didn't know the pin so i just put eight 1 then it said put in new code so i but in eight 0 the it siad smart chip rejected
  • xzcv May 11, 2010
    not any solution i want answer
    Problem Solver:
  • 12 Answers
You need to do some testing first.
Put your sim card on another phone (should be unlocked or the same provider) and see it it works.
Put another sim card on your phone (should be the same provider sim) and see if it works.
From there you can check where the problem lies.
Posted on Jan 20, 2009
  • charmaine Jun 19, 2013
    my sim is been rejected
What can i do if the mobile tell me sim card rejected
Posted on Jun 03, 2008
  • 4,102 Answers
Hi what phone is the network on and also what network is the sim card if the phone is brand new and the sim card was in the box then what you might need to do is register the sim card first if you look in the book that tells you how to get started it will tell you how to register the sim card.
If the sim card still dont work then it means that sim card has not been used for 6 months as its new and still in box then the chances are the phone has been in storage for 6 months or more after 6 months the sim cards get switched off and another sim card will get that number.
But you will find this out by calling the number to register the sim card.
Let me know what network phone and sim are ok
Posted on Apr 09, 2008
  • paul proctor Apr 09, 2008
    If the phone is new and came with the sim card then in it should work fine the only thing you might have to do is register the sim card using a land line as your phone wont accept the sim card untill it is registered you can do this calling the number provided in hand book.
    Also some phones you need to leave on for 24 hours to register sim card but it will tell you this in the user guide. if it still dont work then take it back as the phone or sim is faulty.
    You need to ring from land line phone to register the sim then once registered you can put sim in phone then it will work.
    What country are you in and ill have a look for you about your network
  • paul proctor Apr 21, 2008
    Sim card rejected means that sim card no longer works either its not been topped up with credit in a set time or someone has got your details and canceled your sim replacing the sim will solve your problem
Change the sim
Posted on Jun 20, 2012
Plz any one tell me how to fix a rejected sim my telenor sim has been rejected and i cant do any thisn to it plz help me
Posted on Dec 19, 2009
If you have another sim card that your not using then go to the mall and ask the teller in the store for whatever company you have to switch the info from one sim to the other, you well still have the same number...... If you dont want to do it that way then simply call the phone company and ask them to onlock your sim....
Posted on Sep 07, 2009
Hi all
N73 model, 3G Service provider, starting problem no display, after trying many times, pin code PUK asked, i put the correct pin number, not accepting, blocked at last SIM rejected. suggest me please. same thing happened previously. once turned off and restart, hard to start smoothly. but by luck i was sucesssful, but this time i am in trouble. worry about my contact, name phone number as well. will it be ok . your suggestion is highly appreciated.
regards
kuntal
Posted on Sep 17, 2008
I got a new w375 to replace my old 171 but the old sim won't work on the new phone. It just says sim reject. Damn, this is the same service provider and I have 300 minutes on both phones...man this sucks...I have to use the old phone until I run out. Anyone out there have any suggestions on this?
Posted on Jul 28, 2008
5 Suggested Answers
SOURCE: sim card rejected
this happen if there is some problem in the sim card holder port ....
there will be loose contact inside the sim card holder is not touching the circuit board inside due to this your sim card is getting rejected ...
as you have told that the phone is a brand new one so i am sure that you will be having the warranty so just make use of it by contact the dealer with whom you have purchased or contacting the company customer care number to get more information about how to make use of your warranty ......
if you dont have the warranty then you must open the handset
and just remove the circuit board & sim card holder and insert it again so that the sim card holder touches the circuit board correctly ...
after this refit the phone then surely your sim will be accepted ....
it is better to use of warranty if you have ......
this is a simple problem if you dont have the warranty also you can only fix it ..
if you just open the handset & set that sim card holder to touch the circuit board that s enough everything will be done and works fine ...
if you are afraid of opening then you must just contact the technician ...
it is just a matter of very little bucks if you contact him also ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Posted on Jul 13, 2008
bsrjth
  • 270 Answers
this happens when ur sim cant establish registration with the preffered networkk . this is not a phone problem . ur sim card may not hve been used for long time (recharging account) . please contact the nearest office of ur network provider
Posted on Nov 06, 2008
iqbalq
  • 41 Answers
hi
you can call the company from another phone and fix the problem by giving them the PUK number.
i hope this will work
Posted on Jan 06, 2009
you may have put it in wrong because i had the same problem at first and realized that it went in totally different then any other phone i have had.
Posted on Dec 25, 2008
I have samsung virgin mobile model no.SCH-B309 but sim shows that uim card rejected what can i do sir please help me and provide me uim no..
you can solve your problem easily,your uim card which is rejected by sim :firstly your uim card insert correctly or not secondly your sim card placed correctly or not if not both you insert the card correctly otherwise your must be phone off because sometimes phone hanged.
Mar 24, 2013 | Samsung SCH Cell Phones
Sim card rejected
hi
Jan 06, 2009 | Nokia 1600 Cellular Phone
Sim card rejected
Nov 06, 2008 | Nokia N73 Cellular Phone
Sim card rejected
When i open my nokia 5800 it says sim card rejected what can i do helpppppppppppp
Sep 07, 2008 | LG Prada KE850 Cellular Phone
Sim card rejected
this is because ur phone is locked to a provider. you'll need to unlock your phone first and then u can use ur phone with any sim
Aug 03, 2008 | Nokia 6630 Cellular Phone
Sim card rejected
thank you
bye
rate my solution
Jul 12, 2008 | Nokia 6230
Sim card rejected
thank you
bye
rate my solution
Jul 09, 2008 | Motorola Mobility C261 Cellular Phone
Sim card rejected
Try inserting the sim card in another phone. If it still doesn't work, the problem could really be with the sim card. Go to your service provider, and request for your sim card number transfered to another sim card. That is if you wanna keep the same number. You could request for another sim card if you'd like. Call your service provider.
Jun 27, 2008 | Lands Phones
Sim card rejected
my mobile create a problem in which it display on its simcard rejected.
Jul 28, 2007 | Nokia 1100
Nokia 2610 Cellular Phone Logo
5,323 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
