Question about Memorex MD6451R Personal CD Player
I can't turn it on, the batteries are good I just don't know how to use it
  • Memorex Master
  • 17,130 Answers
Place a cd inside the tray and close the door. If there is a power button on the side shift it to power on. Now the display should ccome on and the cd must start turning. If you get a reading and the clock counts then plug in the headdphone jack into the small headphone socket and increase volume. If none of these happens you will have to check from thebegining. check your bateries, clean your head and check. If no display , you have a failure in the board, if display come and no reading, your opticcal unit is faulty/. I hope this helps you. Good day
Posted on Jul 15, 2010
How do i know if my starter in my 1986 crown vic works
if the engine turns over when cranking its working. you don`t say what the actual problem is. at the starter on the large terminal you should have battery voltage all the time. on the small terminal you should have battery voltage only when trying to start the car. if you do have power here then while trying to start the car tap the starter if it attempts to turn over the starter is no good. if you don`t have power at the small terminal then you will have to check for power at the solenoid/relay on the inner fender on the drivers side on the S wire when trying to start the car. this wire feeds battery voltage to the starter on the small terminal, if you don`t the solenoid/relay is bad. if you do then you will have to check for a damaged wire from the solenoid/relay to the starter. sometimes the starter motor could have a bad ground connection were it bolts up to the engine.
Aug 24, 2014 | Cars & Trucks
Tip
7 ways to extend the life of cell phone battery
Batteries don’t last longer than a few days. But to be fair to the battery designers we have to admit that nowadays’ smartphones require much more energy than phones 10 years ago. We can’t really compare them but what we can do is use them with more care. Here are a few good tips how to go about it:
1. Turn off your Bluetooth – I find Bluetooth to be the most power hungry application; turn it off when you don’t use it
2. Disable sounds and vibrating alert – you don’t really need keypad tones to be on, do you? What about vibrating? It is surely useful on the meetings or in a cinema but most of time you’ll do just fine without it; I usually set up a vibrating profile to be used in places like cinema or theatre and in all other profiles I have vibrating turned off
3. Brightness – lower the brightness of your screen; not too low, otherwise you’ll destroy your vision
4. Setting the Power saver time-out and the Light time-out to the low values will help too (you’ll find them in the display settings)
5. If you are not using an application switch it off – you’ll get a list of all active applications by long pressing the menu button; this is a general rule that can be applied to any device
6. Games – it’s fun to play games on your way to school but they are power-hungry beasts; I can’t tell you not to play games but think about your battery when you are playing
7. Turn off your phone when you don’t use it – I know that for many of you this is not an option and I’m not sure if turning it off and on is even good for your battery but I heard this tip from so many people that I just had to mention it
on Aug 07, 2010 | Cell Phones
94 Accord cuts on and shuts off.
we just had the same problem with my husband car, he needed a fuel pump and distributor...now he says he doesn't have any problems....our mechanic said don't keep turning the ignition cuz eventually you'll mess up the starter
May 01, 2013 | 1994 Honda Accord
Have a 2002 ford Windstar just changed alternator and battery. Light on blinkers keep flashing and car won't turn over I put 5 gal. Gass in soi know it has fuel but it sounds like it don't have any
was it running before you replaced the alternator and battery or did it not run,and you thought that the battery and alternator was the cause of it not running. if a motor cranks and not start the battery and alternator are good. you need to check to see if the fuel pump is working and if you have spark
Feb 08, 2013 | Cars & Trucks
2005 Dodge Truck 2500 / Brake lights flashing while truck turned off / dead battery
i don't know why but dodge trucks back feed threw the trailer lights and leave light on
Aug 31, 2012 | 2005 Dodge Ram 2500 Truck
As you your battery life of your notebook ? The main problem with laptops is often the battery , after a year of heavy use loses almost 50 % of the power . How can I prevent that ? Have you could keep a...
I have some tips to keep your laptop battery live longer
1.don't undercharging and overcharging,laptops battery can reach 100 degress Fahrenheit and such heat can damage your battery. slowly but sure
2.ideally,you should try to keep your battery charged from 20 percent to 80 percent. i know it's inconvenient to unplug the charger before it reach 100 percent,but try to keep it charged near 80 percent
3.try to charge your battery constanly,and unplug it when you think its almost fully charged,overcharged can heat your battery and damage it
4.keep your laptop as cool as possible,don't try to charge the battery when the computer is turned on,even if the battery is going to 0 and you still need to use it,just shut down the laptop first and charge it,at least until the battery is charged 20%,unplug the charger and turn it on
Well,there are many other tips to keep your battery alive,but i only have those 4,thanks for using fixya
and good luck with the tree-planting project,i love environment very much
Aug 29, 2012 | Dell Latitude D630 PC Notebook
Sony laptop dead problem
Could be many things. Let start with a couple of easy ones.1) Unplug charger from computer and outlet, take battery out press power for at least 30 sec. Plug every thing back power on. 2) charger bad won't turn on or charge battery, try diferent charger if don' know how to use a voltmeter. 3) power jack loose or broken. 4) last and worst mother board circuits transitors etc... btw processor, video card or input devices fried. Buy new board from ebay. Don,t fix it. Not worth it. This is Only if laptop gives completely sign of not turning at all. No lights, no hardrive or no working or fan. No signal of life. If couple of lights do turn on it can be the ram or video card, play with ram a bit. Good luck.
Dec 09, 2011 | Computers & Internet
My laptop battery says consider replacing the battery
Windows 7 on laptops continuously monitors the charge holding capacity of the battery and starts warning well before time (when the charge holding capacity of the battery decreases below 40%). The battery may still capable of holding charge and will give good back-up, which means you don't have to replace it (not at least now). However, you may replace it when the back-up time would decrease considerably.
If the battery is still providing backup, you can turn off the message by clicking the notification icon and turning off the notification (un-check) as shown below: -
You may like to refer to Article from Microsoft for further details
Please note that upon every charge and discharge the charge holding capacity of the batteries decreases and ultimately battery becomes dead and needs to be replaced. To enhance the battery life, it is recommended to run the laptop on AC power adapter (if it is available) and in case of AC unavailability, don't drain the battery completely. Use the laptop on battery power only when extremely necessary.
About buying a new battery, I would suggest that the battery may be bought from authorized dealer of the manufacturer or any computer store but most importantly, I suggest that you buy a new genuine battery (not any replacement), as genuine battery would last longer and serve you best.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 08, 2011 | Samsung Computers & Internet
I can`t find the fuse for the dashboard lights on my 2000 jetta.
First, make sure it's not that your dimmer switch has been turned all the way down.
Check fuse 22 and 23. If they're good then you may have a bad ground somewhere. Check the board and fuse box under the battery (yes, I know - but thats where vw located it) for corrosion.
Jul 20, 2009 | 2004 Volkswagen Jetta
Memorex MD6451R Personal CD Player Logo
443 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
