Question about RCA L32HD35D 31.5 in. LCD HDTV
Volume is there a way to increase the volume, this TV only goes up to 50, sometimes it is fine but not all of the time. I am loosing my hearing, so I need more volume.
techman
  • 3130 Answers
SOURCE: Volume goes up on its own and stays up.
Aren you sure that the volume up button is not stuck in . It should feel just like the rest of them A little click? It could still be shorted,or the capacitor across the switch could be defective. If all this seems good then the eeprom, or the microprocessor,or the line or trace going to the volum button could be shorted. This is not a repair you should attempt unless your a tech. Now the button thong can be looked at after the set is unpluged and the back is off, gently slide out the chassis toward the rear of the set just a little and slide it back to see if the button is released. if that dosent help then you will need to take the set to The repair center. Good Luck
Posted on Jun 10, 2006
tvtek
  • 1284 Answers
SOURCE: No Volume Unless
The most lkely cause to strange issues when you have an RCA/GE or Proscan with Gemstar is the Gemstar board itself.
Posted on Jan 25, 2007
CLUEPATEL
  • 138 Answers
SOURCE: Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Posted on Dec 23, 2007
quare3
  • 48 Answers
SOURCE: RCA TRUFLAT VOLUME,CHANNELS MOVE ON THERE OWN
i would honestly suggest if you still have the receipt return it back. dont forget your rating thanks.
This is a very common problem for RCA TV. I have one as well. or go to www.tv.rca.com/ there are free manual there
Posted on Jan 25, 2008
  • 1011 Answers
SOURCE: Problem with the volume
what about sound bar in the tv that shows how much is vol.
is it remain normal or go at full ..
check if it remains normal then its another problem
if it goes also full then it might be software problem
Posted on Aug 14, 2008
Kenwood KA 995 amp. volume control, as you increase or decrease the sound, a loud clicking sound is heard.
Katrina, this sounds like a dirty potentiometer (volume control knob). Try turning the unit off, and exercising the knob. That means turn it full turns, many times, like 70 times. Then try it again with power. Sometimes this helps.
Sep 21, 2016 | Kenwood Audio Players & Recorders
TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
Poor quality sound - low volume on Netflix. Everything fine on regular TV programmes.
You have to go to the sound mixer on your PC and increase the volume on Internet Explorer, Microsoft Silverlight also.
To find the mixer try clicking on the speaker on the taskbar.
Mar 05, 2014 | Samsung LA32A450 32 in. HD-Ready LCD TV
Samsung TV Version CZ04 volume reduces itself and whenever goes back to normal
Your volume goes down or up depending on the demand (number of viewers} viewing the channel at any given moment. That is mormal.
Nov 28, 2012 | Televison & Video
Sony BDVE870 Low Volume
use equalizer to increase volume
May 19, 2012 | Sony Audio Players & Recorders
THE VOLUME, USING THE REMOTE AND THE TV, DOES NOT GO ABOVE 50%. THIS IS NOT LOUD ENOUGH FOR THE OWNER WHO IS HARD OF HEARING. IS THERE A WAY TO INCREASE THE VOLUME. IT IS A SANSUI MODEL #LCDCD1909.
well if the volume wont go any louder on the tv even without the remote that can be a problem what i would recommend to do is get a stereo that you could hook up to the cable or satellite or if you use digital antenna use the output of a vcr to plug into a stereo system then you can use a stereo to increase the volume.
Sep 18, 2010 | Sansui Televison & Video
Low Volume despite High setting on TV
HI I am having the same problem. tv sound is fine, then fades so that 50 is the only sound volume to hear the show. It happens intermittently. Did you get your's solved? thanks
Jul 06, 2010 | JVC AV-27050 TV
Volume turns up or down on its own
yes direct into the buttons the WD40 is the best thing i've ever seen, that will not damage anything you can spray it without fear and then try to activate the buttons a few times, of course with the tv off.
May 20, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
RCA L32HD35D 31.5 in. LCD HDTV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
