Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv problem when i turn my tv on it has no picture but sound i turn it off then try it turn it back on i get the picture but no sound i try it couple more times and it works fine wat can i do to fix the problem
  • 1314 Answers
SOURCE: rca 2720ba 52 inch projection
if that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rca cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Posted on Jan 02, 2008
SOURCE: RCA 52 inch tv will not come on and has no sound
I have the same set (D52W19B w/ TC222 chassis) with same symptoms. The set turned on a few times but I heard a sizzle. So I took off the back panel and tried to turn it on again. I heard the tube power up and then saw what was sizzling: an arc under the board about an inch behind the flyback kind of near the big metal heatsink. Any ideas? The tv was given to us so I'm not afraid to tinker with it.
Thanks!
-Gabe
Posted on Oct 13, 2008
egadgetguy
  • 258 Answers
SOURCE: T.V. won't turn on
This is a classic symptom of high voltage shutdown. There is probably a bad flyback [high voltage transformer]. The problem is one for the techs. Replacement usually involves also replacing several H/V components as well. The TV tries to come on, energizing the H/V circuits, then, the protection circuit detects too much current and goes into "protective shutdown" and then tries again. After a few tries, it stops trying. The protective circuit us there to keep from blowing breaker or causing a fire.
If it's an expensive set, take it in to the shop, otherwise go shopping for a new one. This repair can run anywhere from $100 - 400.
Posted on Jan 01, 2009
SOURCE: I have a rca model
the projection lamp is likely burned out
Posted on Dec 10, 2010
ginko
  • 19396 Answers
SOURCE: RCA model# M50WH185- I turn
Hi.
Since the problem is intermittent, start checking from the lamp cage door lock. A defective lamp cage lock can result in similar problems.
The same problem is commonly given by a defective lamp. There is no way of testing a DLP lamp, then the lamp gets usually replaced before repairing the rest. If the lamp has many hours of use, replace the lamp first, then work on the rest.
If the lamp is OK, then it is either a bad PSU or a defective ballast. The PSU supplies power in different voltages. Each line is independently used for a different function. If the PSU is defective there can be intermittent power to the lamp while the rest of the TV functions are working. Power to the lamp goes through the ballast. The ballast is the board that supplies power to the lamp. With both PSU and Ballast problem you may have video going off, or TV going to forced standby with LED blinking with no additional problem (no sound or picture issues before going off).
Ballast and PSU are tested reading voltages. If both parts test OK, then the problem is the digital controller board. In that case the protection circuit it is likely faulty.
Here a service manual for this model at $7.99: M50WH185 ...
Posted on Jun 13, 2011
Just bought an LG Plasma Screen TV. 50' 50PV400 I turned it on, and the picture was there. After a couple minutes the picture is no longer available and the screen turns black while the sound...
The tv is faulty and the fact that it failed immediately after you have started it for the first time is a clear indication of a manufacturing defect.
Take the tv back to the seller and ask for a replacement one or your money back.
Jun 01, 2011 | LG Televison & Video
When trying to turn on my tv, the green light blinks a few times then the red light blinks a couple of times then automaticaly the tv shuts off. There is no picture at all. It makes a couple of sounds like...
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
Jun 04, 2010 | Zenith E44W46LCD 44" Rear Projection...
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
I was watching tv and out of nowhere the tv turned off and now will not turn back on for more than a couple seconds. When it does turn on it makes a click noise then turns off, with no sound or picture.
Dec 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
RCA HD61LPW42. No picture/sound.
Ur high voltage FBT,is dead the block of plastic with a red wire with a cap hook to the CRT(tv tube).Might also have to replace the whole power board?Because just couple parts it hard to determins,what else also ready to burn next!
Sep 12, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Picture goes out - but has sound
i have had this problem on one of my tv s all i did was remove the back of the tv and re-solder all the joints around the tuner (thats where the arieal goes) they go with time because the joints there get so hot . hope this helps
puggy
Jul 07, 2009 | Televison & Video
Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Apr 07, 2009 | Sharp LC20SH7U Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
