Question about HTC XV6900 Cell Phone
Hello, my HTC touch XV6900 will not turn on is there any way you may be able to tell me how to fix this issue.
  • 4,737 Answers
1. Check your battery voltage, you can do this with your tongue, if you feel a salty taste with pricking effect, then there must be no problem with it, but if you are not familiar with this testing, you'll not be able to assume the voltage.2. Please check your battery, if possible, you need to try it using another battery so that you can make sure it's not the culprit.
3. Check your battery connectors and interfaces, you can clean them using an eraser (rubber)
4. Remove everything (like memory card, sim card, etc if any) and switch on using the battery only.
5. If you have the flashing software, you can boot it from there, if you don't you can go and check it from a mobile repairing shop.
6. Verify battery is charging even if the phone is switched off or not.
If all of the above can't fix it, then there's an internal problem, which would be difficult to repair. You only choice is to visit a service center for Htc handsets.
I think there must be a cause, how this started. If you can, please let me know when and how it failed. Good luck. Thanks for using FixYa.
Posted on Jun 03, 2010
Xv6900 forgotten password
Call verizon and tell them you are locked out of your phone.
Oct 01, 2013 | Verizon Communications HTC XV6800 Cell...
My XV6900 cannot connect to the internet... a screen pops up every few minutes looking for me to input an IP address (currently filled in with a bunch of zeros). No picture messages
Hello and thank you for your question,
The settings for your phone to properly connect to your cellular provider have seem to have been changed. To get these to the proper settings please contact your cellphone provider so they may fix this for you.
Please remember to rate this answer for your ratings help me better serve you and the community of others like you needing help.
Once again thank you for you for using Fixya.com and for all your technological needs please continue to use fixya.com where you will find the answers that Fixya problems.
Sincerely,
Zachery D.
Fixya.com - Guru: zdeuyo
Mar 28, 2011 | HTC XV6900 Cell Phone
Forgot login password for HTC touch 6900, how do I reset it?
You will need to perform a hard reset on the phone.
Be warned, this will ERASE EVERYTHING. Not just the password. The phone will be like brand new again. EVERYTHING will be gone.
Here is how;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your XV6900.
2. Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:
This operation will deleteall your personal data,and reset all settings tothe manufacturer defaultsettings. Press ENTER torestore manufacturerdefaults, or press Camerabutton to cancel.
3. Release the TALK and END buttons, and then press ENTER on your XV6900.
Warning! Your XV6900 will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Jan 07, 2011 | HTC Cell Phones
Quiero saber si el mobil htc touch model 6900 tiene wifi
Su coneccion inhalambrica es atravez de Bluetooth segun especificaciones del fabricante. Si no tienes el manual lo puedes bajar de esta direccion http://www.phonedog.com/products/htc-touch-xv6900/manual/
Jan 04, 2011 | Computers & Internet
I am trying to unlock my htc xv6900 with the touch unlock program but it will not generate any code in the unlock_code.txt file. any suggestions?
There can be many ways to Unlock your phone.
As far as i know unlocking by codes is the simple and safest way.unlock using software delete some information in memory i unlock my phone using codes ,http://www.superunlockcodes.com/htc/rs12wp8/ you can unlock your phone here
I used codes to unlock my cell phone. i had my unlock code and my phone was unlocked.
you need to specify the country and network provider
Dec 10, 2010 | Cell Phones
How do i get my HTC XV6900 unlocked or unflashed
if you are trying to unlock it from the network to use on a different providers network or to use internationally than you need to get the unlock code from the provider that supports that phone. keep in mind if you are going to use it on a diff network than what is was made for it may not work up to its full functionality, especially internet, bc the phone was designed for a specific network and the settings will not be the same.
Mar 14, 2010 | HTC XV6900 Cell Phone
Verizon XV6900 can't send/receive MMS
Just to make sure, you have to have internet to receive mms mssges
Dec 23, 2009 | HTC XV6900 Cell Phone
I have a Verizon XV6900 or (htc) 6900 and all
Did you try plugging another charger or connecting it to your pc by usb cable if it shows charging its the power button
Dec 10, 2009 | Computers & Internet
Touch Screen is not working
Since this is the case you may need to soft reset the phone.
The touch screens normally give problems whenever there is a little pressure applied to its surface e.g when you don't use a pouch but place the phone in a tight jeans pocket and thus will need,screen reallignment.As you may already know.
Now your phone has a soft reset function...try it! Or turn it off,remove the battery (not immediately! so you don't loose your settings then re-insert it after 25 secs.) and do a restart. This should allow you access the screen allignment settings so that you could fix your screen.
Hope this helps.
Sep 23, 2009 | HTC XV6900 Cell Phone
User manual need
Hello u can download the manual here. Please rate me. Glad i could help you....paste this in your address bar...http://www.phonedog.com/cell-phone-research/htc-touch-xv6900_user-manual.aspx
Dec 23, 2008 | HTC XV6900 Cell Phone
HTC XV6900 Cell Phone Logo
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
