Question about Vivitek V37835 46 in. LCD Television
Humming tv hi where did you order the part from and can you give me step by step instructions??? thanks
  • Anonymous Aug 02, 2008
    42' dlp needs color wheel
  • PATRICK BEVERLY Oct 26, 2008
    CAN YOU TELL ME WERE DID YOU ORDER YOUR COLOR WHEEL FROM THANKS.
    Problem Solver:
  • 3 Answers
Try Vance Baldwin for the part.
Posted on May 29, 2008
How do I programme my universal remote urc22b
  • If there's a book that comes with the remote follow the instructions for it. It usually tells you how to scan for the right signal. sometimes it even gives you the code for the type of tv it is.
  • If that doesn't help try checking online for the code that needs to be put in.
  • sometimes you can find step by step instructions on the website for the type of control you have.
  • If it's a tv provider remote I suggest calling your provider and they can give you step by step instructions.
Feb 19, 2015 | Universal Televison & Video
Samsung Refrig Compressor Problem
Can you tell where the hum is coming from?
Jul 10, 2013 | Refrigerators
Using your DVD-V4600, how do you play a vhs tape on TV? Need step by step instructions.
In order to watch either DVD or VHS on your TV ,you need to make the following connections ..
  • You need to connect "DVD Player / VCR Combo" to" TV " as (Audio/video output of DVD Player / VCR Combo -TO- Audio/Video input of TV) ..
  • use either "RCA analog (red/white +yellow ) " or "SCART "or "Optic " cable.(any standard optical cable )...if exist ,optic is the best way to connect it..Remember your DVD Player / VCR Combo 's "OUT" goes into" IN "of the TV ..
  • pls also remember,wherever you connect your DVD Player / VCR Combo on your TV ,you should switch the source selector accordingly to correspond to the connection on the back...
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Samsung DVD-V4600 DVD Player/VCR
Hi, my old fisher paykel top loader without lcd display is unable to drain or spin. it occurred after I advance the wash cycle from wash to spin. the washer stopped abruptly and failed to drain or spin...
Hi just read your posting.Now you said in your posting that the motor is hot to touch.Is this the main drive motor underneath the machine or the pump which has a fan attached to it?If it is the motor with the fan attached then your pump is jamming.Bail most of the water out by hand with a small pot or bucket because then I can guide you step by step to remove the pump to remove the object which is jamming it.Please reply when most of the water is out and I will give you step by step instructions to remove the pump.
Aug 11, 2010 | Washing Machines
Sebo X1 - Doesn't work although there is power
I'm not sure about this one but, as nobody else has picked it up, I'll give it my best guess. You say the machine just hums - by which I take it that there's no suction at all. I wonder how old your Sebo is... if it's seen a lot of work, it's more than likely that the carbon brushes in the motor have worn out and need replacing. This is not a difficult job, but you do need to be comfortable tinkering with machinery to attempt it yourself. Otherwise you will need professional help. If you want to do it yourself, post a reply here and I'll give you step-by-step instructions.
Apr 21, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
I need a diagram of how to set up the analog converter box or instructions.
I am posting the instructions of how to set up the analog converter box :-
Hope it will you.
· Things you’ll need:
Analog TV, antenna, two coaxial cable, and converter box
· Instructions:
Step 1
Unplug coaxial cable on the back of TV "antenna in" (RF) port
Step 2
Insert coaxial wire into the "antenna in" on the converter box
Step 3
Use second coaxial wire and plug in the converter box, "out to TV" port. Plug the other end into
“antenna in" on the TV
Step 4
Power on the converter box and TV. Change TV channel to 3 or 4. Follow on screen instruction to
Complete setup.
Step 5
After setup you will begin to see more channels than before with better clarity. Some stations will broadcast two or three channels. Enjoy
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 18, 2009 | Televison & Video
Tv only go to channel 13
Check your owners manual for instructions to program your remote(you didn't list a model number so I can't give you step by step instructions.) If that doesn't work, you have 2 options. 1) Contact your TV manufacturer for help. 3) Purchase a 3rd party remote that works with your tv.
Jun 03, 2009 | Philips Televison & Video
Light Engine for Toshiba 62HM95
Hello thuertam,
I would first suggest that you spend $19.00 for the schematic and service manual for this device. In the service manual you will see the factory approved instructions on how to remove the light engine. This is the best course of action, because even though some here can give you excellent instructions, the warranty on the parts might be voided if you install incorrectly. In addition if you have the service manual it can guide you through steps that might be left out with secondhand guidance.
A good sight to get schematics frrom is http://www.servicemanuals.net and http://www.manualsparadise.com
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 12, 2009 | Toshiba 62HM95 62" DLP HDTV
Can anyone give me step by step instructions on how to remove light engine from sony kdf60wf655 tv thanks
I have the same Sony TV and just replaced my bulb. I ordered the bulb from sony.com and the package included the allen wrench you will need and simple step by step instructions are also included. There are two hand tightened screws on the lower rear corners of your TB. Remove these screws by hand and remove the botton gray panel of the TV. You will see the light package in the bottom center. Remove the hand tightened screw and swing the metal holder away. The gray cover now will come off by pulling lightly on the bottom. This will expose the lamp. You will need the allen wrench supplied with the bulb to remove the allen screw on the left. Once removed, the plastic cage containing the bulb will slide straight out. Push the new bulb in and tighten the allen screw. Replace the gray cover and swing the hold back in place the hand tighten the screw that holds it in place. Replace the gray bottom panel and hand tighten the two screws on the lower rear corners. That's the whole deal.
Jan 17, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Pioneer avh-p5700 dvd player
You can download installation and operation manuals at this link (free registration required): http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070347_192089338,00.html
May 26, 2007 | Pioneer AVH-P5700DVD Car DVD Player
Vivitek V37835 46 in. LCD Television Logo
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
