Question about Whirlpool Duet GHW9150P Front Load Washer
Water leaking from the door with heavy load - Whirlpool Duet GHW9150P Front Load Washer
  • 159 Answers
The door seal needs replacing or try cleaning the glass where it makes contact with the door rubber first.
Posted on Jun 03, 2010
Cold water leaks into tub when machine is off
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the WATER INLET valve
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace inlet water valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace pump .
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. 9696d86e-1b8b-4b2e-af2c-6f3a3ae921dc.jpg
May 23, 2013 | Siemens WK61420GB Front Load Washer /...
Leaking water
Make sure your vent tube on the dryer going outside is clean the entire length and the outside door/loovers are free
Apr 23, 2012 | LG DLG8388 Dryer
Kenmore elite. Loosing water from bottom only when in use.
If your FRONT LOADER is leaking, the following link can give you guidance on how to inspect the washer to determine where the source of the leak may be coming from:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, or if your washer is NOT a FRONT LOADER, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
NOTE: The leak may appear to be worse with heavier loads, because more water is in the drum and it is being displaced by the laundry load.
Jun 25, 2010 | Kenmore 24032\24036 Top Load Washer
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
1999 Blazer air/ water leak top forward corner
i've had leaks like this and they are hard to find,my solution is close all doors and windows turn on your heater blower to high and take a tablespoon of liquid dish soap and mix with water and then use a paint brush to apply and go around the windows and doors with this solution if you see bubbles you have found your leak, then you can fix the problem,hope this helps.
Sep 16, 2009 | 1997 Chevrolet Blazer
Leak with heavy load
Is the machne noisy? If not, it may soon become noisy. Sounds as if the grease seal protecting the basket spindle bearings is leaking. soon the bearings will fail
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG front load washing machine water leaks with heavy loads
If your water is leaking with heavy loads, the first thing you want to check is the gasket (door boot) attached to the tub. Look for holes or rips in the bellows part(where the water settles) and around where it contacts the door. Any nicks or holes will cause leakage. Also, check the glass dome on the door towards the bottom. If it has dirt or hair buildup on it, it will leak with any pressure on the door.
Jul 15, 2009 | Washing Machines
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
How do you clean the drain filter
The door should be locked closed when a cycle begins.. That may be part of the problem.. however here is a link to the service manual for you to examine Note that page 7 shows the whereabouts of the filter,..Page 10 shows how to test the door locking system as well as drum fwd and reverse rotation...and how to drain the remaining water in the tub with the hose... http://136.166.4.200/contents/Laundry/WM2688/WM2688_Service_Manual.pdf
If you have never cleaned the filter then there is a good chace it is blocked up and water cannot drain in the normal manner so I would examine and address that first. If I've helped you resolve your problem, please input the appropriate rating .. Good Luck...
Sep 28, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Whirlpool Duet GHW9150P Front Load Washer Logo
138 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
