Question about Vintage Keeper chillR 300 Wine Cooler
My Koolspace cooler in my VK250 wine fridge quit cooling
About 1-1/2 yrs old. fan runs all the time and cooler has quit cooling. I have cleaned the cooler and unplugged overnight and still does the same thing. I have tried several service companies but no one seems to work on Koolspace. Can you point me towards a solution or repairman. I am located in Spring, Tx (North side of Houston).
  • Bheiam Apr 21, 2008
    Same thing here. I discussed with a Refrigeration guy and he told me about $150 to "maybe" fix it. I ordered a new one last week for $200. Not very happy with it. It certianly does not get worked that hard to break that quickly.
  • doughsl Dec 04, 2008
    unit now blows hot air. this is a 2nd new replacement unit. disappointing product.
I have the same problem with mine and have tried the same things as you have. I took my unit to a air conditioner service place and they said these units are not worth fixing. It would cost about $150 to add a valve so they refill the gas and then try to find out why it is leaking. I am about to order another one which makes me vary mad. My unit is 1.5 years old.
Posted on Apr 21, 2008
How to tell the year of a koolspace wine cooler
That will always depend on the Manufacture of your Koolspace Wine Cooler. If Koolspace keeps record's they will ask you for your serial number. It does appear you have an eliete model and brand name so I would think they are well ahead of the game.
Fax: 403-283-6111
Calgary Phone: (403) 283-7575
Toll-Free: (877) 283-7575
Design/Construction Inquiry: Click Here
Wine Cellar Services Inquiry: Click Here
Accounting Inquiry: Click Here
Cellar Coordinator Inquiry: Click Here
Gallery
If you have warranty issues with your cooling unit (ChillR or Vintage Keeper Nuvo), please contact the manufacturer directly at www.wineracking.com or 1-888-274-8813
We have set up our Calgary space to introduce you to the most stylish and sensible storage and lifestyle accessories for the discerning wine-enthusiast.
Please feel free to drop by our showroom at any time during regular business hours. If you prefer we can arrange practically any time that is convenient for you.
10:00 am - 5:00 pm : Mon - Fri
Saturdays by appointment only
If this was a Whirlpool question I could find it myself with model and serial If helpful please rate this solution, Thank You, Sea Beeze
Nov 24, 2011 | Refrigerators
I have a Koolspace 250 nuvo in my garage. It is having a hard time cooling in the summer. It is holding 68-70 degree F when set to 52 degrees. Can I make it insulated or put a fan above it to help? Can it...
You should contact Koolpace regarding this issue. They can be reached at:
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 04, 2011 | Vintage Keeper Koolspace Wine Cellar
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
I have a Koolspace AA6 Tuscany free standing unit. Sn 05314-11. Power went out cooling unit will not restart. I get the thermostat to read and fan to turn for a while then goes into high temp alarm mode.
It seems like this cooling unit (AA6, also Grand Cru 800) just doesn't last as per numerous postings that I found when I was trying to find a replacement unit. Best advise seems to be get a higher output unit that will fit application.
May 14, 2010 | Vintage Keeper Koolspace Wine Cellar
Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Jan 28, 2010 | Marvel 61WC Wine Cooler
Koolspace NUVO wine cooler recharge
do you have a recovery machine and gauges you need to tap both sides to check the high to and it needs to be vaccumed down to remove moisture ,find and fix the leak. leaks arnt verry common un less someone broke a line somehow. if the compressor is running it is more likley it has a restriction or bad valve in compressor, hooking to high and low sides will determine which if is less than 5 years old it could be under warrant still most sealed systems have a longer warranty than the rest of it is the evaperator getting cold at all.
Dec 31, 2009 | Vintage Keeper Koolspace Wine Cellar
My Vintagekeeper Tuscany 220 wine fridge is making lots of unnecessary noise.
Hello, this is a common problem when parts start to wear in the motor. They rattle and clang allover the place, depending on age of fridge you can get the motor replaced and regassed. Or depending on age it may be time to replace the fridge. I hope this is of some use.
Nov 04, 2009 | Vintage Keeper Koolspace chillR Cooling...
Koolspace 600 Problem
You'll need to replace the fan. The original fan bearings wear our after a couple of years. It's pretty simple to drill out the rivets and replace the fan. I suggest you replace all four with ball-bearing fan units.
Sep 19, 2008 | Vintage Keeper Koolspace Wine Cellar
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Vintage Keeper chillR 300 Wine Cooler Logo
1,023 people viewed this question
Top Vintage Keeper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vintage Keeper Refrigerator Expert? Answer questions, earn points and help others
