Question about Water Heaters
Aquavac 42 tankless water heater: we cannot find a source for parts in US. Please help
Hello aknapton:
I just removed a working aquavac 42 from our home and upgraded. You can have the whole unit if you would pay for shipping.
It worked when we removed it. It was fussy about the standing pilot and had to clean the thimble jet a lot (dirty propane) but it did work. let me know. norm@finetuningauto.com
Posted on Aug 30, 2010
  • scrappy228 Dec 25, 2010
    do you stll have your aquavac 42?
  • normaneric Dec 25, 2010
    Hello: Sorry to say, I shipped the burner and exchanger to california about two months ago to another aquavac 42 owner.
    norm <"}}}><
Does the water heater produce radiant heat to the exterior of the unit
1) No.
NO.
Do NOT store combustibles close to a water heater, fireplace, or any source of ignition, including HVAC, space heater, microwave, appliance, etc.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#bang
2) Tankless water heaters do not have FVIR safety features found in tank-type gas water heaters rated less than 60,000 BTU.
3) Tankless water heaters draw large amounts of air into combustion chamber from surrounding room, and this air feeds directly into the burner flame with no barrier.
4) If flammable vapors enter tankless, then it can cause fire, explosion, conflagration.
5) Read product manual and safe a life.
Feb 07, 2013 | Noritz N-0751M Residential Gas Tankless...
RichmondG40PVpower vent gas water heater
1) Type and brand water heater unknown.
Copy following link for Rheem-Richmond tankless error codes:
2) Question posted under Richmond tank-type power vent.
Error code 24 appears to be Rheem-Richmond tankless water heater.
3) Add a comment with more information about type, brand, age of water heater including what you have tried so far.
4) Call service technician to catch up on required yearly maintenance.
Dec 28, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
What size venting do I need for the ptg-42-pvn?
3" category III stainless for special venting
Tanklessking shows Category III stainless steel vent kit for this model
3" vent
http://tanklessonline.com/rheem-water-heaters-RTG42.html
ptg-42-pvn has minimum 31,000BTU and max 118,000BTU
Max water temperature 120 degrees F
Spec sheet says: 3" special venting
http://www.palomatankless.com/products/42/specifications.html
Hart and cooley show special vent 3" stainless thru-the-wall vent
http://www.hartandcooley.com/specialgasvent/PDF/851515%20Tankless%20Water%20Heater%20Installation%20Vent%20Kits%20sell%20sheet%20-%20HC%20-%20low%20res.pdf
Hot water sources shows thru-wall or thru-roof
http://www.hotwatersource.com/RTG42PVN-Rheem-Indoor-Natural-Gas-Tankless-Water-Heater/RTG42PVN,default,pd.html
http://waterheatertimer.org/pdf/Tankless-roof-vent-installation.pdf
Aug 17, 2011 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Flow sensor has calcium build up in it not spinning
Usually when a part has build-up that signals part replacement.
I am concerned with condition of other parts, since build-up occurs in more than one place.
Replacing one part is no guarantee that problem will be solved, and just as likely the new part will cause unit not to work.
If you have Tankless, then open following link for troubleshoot resources before you call service technician:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Tankless cannot be exposed to water with more than 11 grains hardness or they will stop working.
Tankless must be delimed and maintained yearly.
Deliming will not restore efficiency to tankless water heater exposed to hard water and mineral build-up. Water softener and filter are required, and these things can reduce water flow and pressure that will cause low pressure and flow that will stop burner from activating.
Water temperatures above 135 can cause minerals to dissolve out of water and coat metal surfaces.
Read manual for troubleshooting and yearly maintenance requirements.
Tankless problems are like bowling on a ship.
Repair most tankless problems yourself, same day, any brand, for around $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 11, 2011 | Bosch Water Heaters
Error code 13, replace burner and vent kit, still getting error code Rheem tankless hot water heater
Before calling service technician, open following link for troubleshoot resources:
The same error code and problem on one person's tankless unit can have different solution than another tankless unit.
This is because tankless require perfect operation of parts and sensors while being affected by incomming water and gas issues, and venting, plus plumbing factors.
Replacing one part is not always the fix, since that part interrelates with so many other parts, each affected by the operation of the other, and operation of the chip and integrity of wiring and wiring connections.
Read manual for yearly maintenance requirements, and calculate those costs when figuring anticipated $1-8 monthly energy savings from owning tankless.
Check that your region has reasonably-priced, qualified service technician for your brand before buying tankless. And check part list and cost of parts before buying any water heater because these factors weigh-in after a few years of operation.
Upvote the help.
May 11, 2011 | Rheem Tankless Hot Water Heater...
Rheem pronto tankless water heater just barely warm model # 74pvn-1. This is in a house we are just purchasing. Also it looks like it may be attatched to another tank water heater , Help please
Before calling service technician, open following link for Rheem troubleshooting resources.
Sometimes people attach tankless to tank-type heater to preheat incoming cold water.
Additional tanks are also used to store solar heat, and some installations have tank-type because tankless is unreliable. Service technician can sort out the function correctly.
http://waterheatertimer.org/Tempering-tank.html
Owner should read tankless manual thoroughly, especially troubleshoot and maintenance sections. Tankless require yearly maintenance.
Since tankless are expensive to repair and replace, you might be able to fire up the tank-type water heater and provide hot water without much cost.
You can also install tank-type gas water heater yourself. Lowes sells 40 gallon for $317.00, and then you offer 10% less.
http://waterheatertimer/How-to-install-gas-water-heater.html
Apr 19, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
I have a RMTG-53dvn piped in parrallel with a traditional water heater because I used to have two traditional in parallel. The unit never kicked on with no trouble code, so I piped in series with a...
I could see how it might not work in parallel. Much water would go thru the conventional heater, so there would be low flow thru the tankless.
Now, the tankless is getting hot water from the conventional. Try shutting the conventional heater's power source off so the water gets cold, then see what happens with the tankless.
Gary
Mar 05, 2011 | Rheem RTG-53DVN Direct Vent Natural Gas...
Need to turn on several different hot water sources to get my heater to fire up. My faucets are low flow, so for some reason the heater will not fire unless there is more demand. It is brand new out of...
When a tankless is installed, they are usually set up with a recirc. Theis keeps the water continuously heating to some degree.
When a tankless is installed into a home it has nothing to heat the water that is sitting in the pipe from its faucet to its heat source. Now as soon as you turn on the faucet, you have to let all that cold water run out until the newly heated water comes out from when you started the faucet.
You could measure the volume until heat and it will be pretty much the same every time for a given faucet.
The fact that your faucets are low flo is only part of the factor involving time it takes to get hot water. Another factor is volume. The diameter of your pipes makes a difference. You can remove the low flo restrictor from the faucet farthest away to speed up the process at least a little.
Jan 04, 2011 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
624 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
