Question about LG 42LC2D 42 in. LCD HDTV
Tv is turning off and on
Took the back off; there is a blue light flashing on the circuit board
  • LG Master
  • 8,457 Answers
There no lamp in the LCD tv only CCFO floorescent light tubes.U can't reset or adjust those CCFO floorescent light tubes.Those CCFO floorescent light tubes are design to work as a whole LCD screen for the tv that it.The tv power supply board is dead.That the board where the power a/c cord plug into it.That the power supply board,it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.On the board u said u see flashing blue light,searches all around for those dead leakages capacitors,they alway bulges up on it tops or puff up on it tops.Replaced those dead capacitors or replaced the whole board.This actions will get the tv power stable again and work.
Posted on Jun 04, 2010
RCA led tv won't turn on
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sep 02, 2016 | RCA Televison & Video
Gva22gled tv turns on logo with vcmes up then red blue lights flash and thats it ,any ideas why this is happening
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Jun 01, 2016 | Televison & Video
Why does it turn from blue to black after 10 sec.?
Dec 15, 2015 | RCA Televison & Video
Model: HD - Z70RF7 projection TV Lamp has blown. I have replaced with brand new lamp and now get rapidly flashing orange lamp light on front of TV, blue power light is solid and not...
Tv turn on now,hear alots of clickings too?Yes.Check the Ballast board,this board might be dead too.The ballast board job is,just it to help to ignite the projection lamp.
Oct 28, 2010 | JVC Televison & Video
HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 25, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
5 flashing light code,unplug CR board,now 8 flashing light code
If you put the "CR" board back on, the error code will once again be 5 blinks. Your problem is likely the TV's IK blanking circuit. The Kine driver ICs on the CRT sockets boards CR, CB, and CG need replacement along with a few components in the 200 volt supply to the circuit.
Feb 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Tv won't come on
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
When the TV goes on protection there are only two possible causes.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Oct 17, 2008 | Hitachi 61SWX10B 61" Rear Projection...
Toshiba TV model CZ27V51 - picture+audio off, red light flashing
hi there, Flashing light red means a shorted electronic component is need to be replaced. do some test at video section, most of it are diode, transistors, transformers. ty
Jan 27, 2008 | Televison & Video
TV will not power up
Opened up the back and vacuumed out all the caked on dust that was everywhere. I used an insulated brush to help remove the dust. Dust can kill heat dissipation. Open up the front and check for fluid under the CRT circuit boards. The one on the right (as you face your TV) is the blue one. For some reason, the diaphram for the glycerin in the blue optic is on the back side and leans down. It tends to leak and spill on to the circuit board below. Some symptoms I noticed: blue shadow, blinking blues, complete blue outage, unable to complete the autoconvergence, and arcing/sparking (from another post). I had to pull out the blue CRT, silconed the rubber gasket, refilled the fluid and repaired some solder joints where the fluid caused a short. Works like a champ now. Tell tale sign is the pool of fluid when you access the front chassis. Pull off the speaker grill and shine a flashlight on the inside underneath the CRT circuit boards and look for the fluid. Glycerin doesn't dry.
Dec 10, 2007 | RCA D52W19 52" Rear Projection Television
LG 42LC2D 42 in. LCD HDTV Logo
172 people viewed this question
