Crown CDVDRW300 DVD Recorder
I've had this recorder for a couple of years, but I have never been able to get it to record from my set to box (Freeview). It lets me watch the channels on freeview but cannot record them. Also what is the correct cable/Scart connections for the set top as I have moved it and cannot find again the correct connection.
Thank you in
Anticipation
  • Bashstkid2 Apr 11, 2008
    I have sorted most of it, I can now watch freeview through the DVD.
    main tv aerial into the freeview box,
    then run a aerial lead from the freeview box into the dvd recorder and from the dvd recorder into the tv,
    if the dvd recorder has no tuner,run main tv aerial into the freeview box,and then from freeview box into the tv
    scart lead from the freeview box into the dvd recorder,
    scart lead from the dvd recorder into the tv,
    But I still have the problem of recording digital channels.
  • Bashstkid2 Apr 14, 2008
    The Venturer TV has only I Scart lead socket.
johnychel
  • 796 Answers
SOURCE: PPDVDR3570H: We also
It is possible to record a Digital Channel using your Panasonic TV's DVB Tuner instead, as all Panasonic DVB TV's output a recordable Digital signal via a rear Scart Socket, usually AV2. (Panasonic LCD & Plasma models may provide additional AV recording options switchable via Menu), while allowing you to watch any alternative Analogue TV channel or vise-versa.
Timer recordings can also be set using the TV's built-in timer to control 'Q-Link' (Next View Link) or 'External Link' enabled DVD's & VCR's.
The only requirement is the DVD Recorder or Video Tape Recorder has a Scart 'Input' socket.
Posted on Mar 16, 2008
Mark_Webber
  • 472 Answers
SOURCE: Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Posted on Apr 14, 2008
SOURCE: On my Philips HDD/DVD Recorder
Dear FixYa, Thank you for your reply to my question. Yes, I have solved my problem by way of studying the plethora of instructions at length. That is the advice I always give to my family if they get puzzled!!! Regards, William Doherty.#]
Posted on Aug 29, 2008
RFICKES
  • 51 Answers
SOURCE: unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Posted on Jan 03, 2009
SOURCE: Hi, I have a Philips DVD recorder which since
My connections were fine, I just hadn't retuned the DVD player into the right extension hence the (no signal) sign.
Posted on Nov 04, 2009
The recorder is 10 years old. All appears to work OK. But on retuning the stations it finds none. Is this because we have moved over to digital and the recorder has an analogue tuner? any fixes?
Hi I have a Panasonic DVD recorder analogue u can connect a digital set top box just tune in the box & set you're input on recorder cheers
Mar 03, 2016 | Televison & Video
My Panasonic DMR-EH55 recorder produces no sound anymore after 3 years of good functioning. There is no sound on TV through the scart interface and also no sound through the analog audio interface to my...
Did you get anywhere with this? I have a similar problem with a DVD/PVR from Woxter. I've tried different cables and changed many of the settings without luck. I've seen a couple of posts which suggest changing country and sound settings (to PCM), so I'll check them out before I call in a repairman to check out the circuitry around the sound output.
Sep 29, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
DVD will not recognise discs
I think that moisture has formed on the boards.
The best thing to do is to take the recorder
and put in a warm room,connect it and leave for 2-3 hours.
Then try with a disc again.
I hope i`ve helped!
Nov 29, 2009 | Samsung DVD-HR730 DVD Recorder/HDD...
I HAVE A 4 YEAR OLD PRESIDIAN DVD/RECORDER. I CAN
I SHUT THE CONVERTER BOX OFF BEFORE TRYING TO START RECORDING
Sep 30, 2009 | Dual Presidian DVD Recorder
Recently, i;ve been trying to record tv programs on my Panasonic DVD Video Recorder DMR-E50, as i have done so for many years. However, lately, whenever i program it to record a tv program using the timer...
Hi Leah,
Good description and good job in narrowing down the problem. The lens is the remaining common denominator.
You need to get a CD/DVD lens cleaner. It should have a disk and a bottle of cleaning solution. They are available in the electronics dept of most chain stores.
A couple drops of cleaning solution on the feathery cleaning element attached to the disk, insert the disk into the machine and hit play. Takes just a couple seconds.
Best regards
Mike
Aug 17, 2009 | Panasonic DMR-E50 DVD Recorder
Awa dvd recorder dr711 can this be connected to a set top box
If it's like the DR620 it will only receive analogue from the TV aerial. I connect the AV out connections on my set box to the inlet AV on the recorder and watch and record through the recorder's "rear AV input" selection.
Jun 16, 2009 | Durabrand DVD-1002 DVD Player
Timed Recording - Won't record VHS or DVD
Bought a new Sony DVD recorder/player with VHS.
Dec 29, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Problem connecting Samsung DVD-HR737 DVD recorder to Set Top Box
I had the same problem, if you go through the channels from your DVD-R remote it should give you the option AV-1 and then AV-2 ? on mine it's AV1 (test it out first and you have to watch what your recording) then it should record from the cable box
worth a try?
May 17, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Nutshell time:
So..
Apr 14, 2008 | Philips VR550 VHS VCR
Televison & Video Logo
202 people viewed this question
Top Televison & Video Experts
