Question about Kenmore 15864/15862 Top Load Washer
Kenmore series 90 bypassing water. doesn't fill instead water flows out the drain tube once it reaches a level just below small load.
  • 1,531 Answers
Raise the drain hose up till the arch is about level with the back control panel. Once you here the water stop draing restart your machine and it should return to normal operation
Posted on Jun 03, 2010
My Kenmore washer fills correctly and then agitates. But it won't stop filling to then switch to the rinse cycle.
Your wash machine doesn't know that the tub is full. Open up your console and look for a vinyl tube attached to your water level switch. Take the tube off of the switch and blow into the tube to clear out any blockages. Then, put the tube back on and test the wash machine. If the problem persists, then you need to replace your water level pressure switch AND the vinyl tube (just in case it has a small hole in it somewhere along the way).
You can buy the switch, which comes with the tube, here:
Switch W10337780
Oct 24, 2014 | Kenmore series 90 Washer Motor 3951550-
Kenmore Elite 90 Series overflows
Check for a faulty water level/pressure switch. This is a diaphragm like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, so does the pressure on the air in the plastic tube and when it reaches a certain leve it activates the switch to shut off the water. Make sure there is no obstruction in the tube and that it is not damaged in any way. The switch can be tested using a multimeter or ohmmeter and checking continuity. A lack of continuity will mean a bad switch. Sorry for your trouble and I hope this helped. Best wishes.
Oct 06, 2009 | Washing Machines
Won't stop filling. Just runs & drains without
Check for a faulty water level switch. It's a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the tube and when it reaches a certain level, it activates the switch to shut off the water and signals the timer to start the appropriate cycle. Check for any obstructions in or damage to the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad switch. Sorry for your trouble and I hope this helped. Best wishes.
Sep 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series doesnt seem to fill up all the way
Check the water level switch. It's a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level it activates the switch to shut off the water. Make sure there is no damage to or obstruction of the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty switch. Sorry for your trouble and I hope this helped. Best wishes.
Sep 04, 2009 | Washing Machines
Over flowing
The pressure switch is what determines at what point the water shuts off. It is located behind the load level selector knob on the control panel. Before assuming the pressure switch is defective, however, a common problem that does occur, is the small air hose that attaches to the switch comes loose and falls off. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
The air hose is what the pressure switch uses to sense the difference in pressure from the wash tub as the water level fills. If the hose comes off the pressure switch, the washer will continue to fill to the point that it overflows. I've seen this a lot. What appeared to be a major problem, turned out to be a 5 minute repair.
Read through the link and let me know if you require additional assistance. I hope this helps you.
Aug 28, 2009 | Washing Machines
Washer not filling up with water at beginning of cycle.
Don't replace anything. You will need to clean out the tube which connects the water level switch to the tub. (or replace that tube)
Feb 26, 2009 | Kenmore Washing Machines
Kenmore series 90 wont fill up to large load level
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 18, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
81 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
