Question about Panasonic DVD-LS90 Portable DVD Player
Unit was dropped. getting message 'disc can't be read'
Unit was dropped. now getting a message saying the disc can't be read
  • Panasonic Master
  • 1,212 Answers
Dropping any electrical unit will almost everytime destroy it. Sad but true...this unit may have many problems. I suggest you replace it altogether! Sorry! Thanks for asking!
Posted on Jun 03, 2010
I can't get into the map on my pioneer avic d3
The AVIC D3 is not pioneers best. The navigation side of the unit is wearing out. The slider slot in the dvd and other moving parts are wearing down fractionally and that is all it takes for the unit to no longer read the high density map data discs. The map disc is a dual layer 8.5gb disc and it is just about max out. (The disc must be in the unit for the navigation to work.) This is a lot of information and the unit must be able to read every bit of data on the disc or it will error out. All it takes is the fractional wear to mess up the tracking of the laser over the disc and cause problems reading the data on the disc. When the unit spins and spins, it is working hard to read something on the disc and will eventually error out if it can't. Also a fingerprint or tiny spot on the disc will prevent the unit from reading the disc. (Clean with a drop of water and soft cotton cloth even if it looks clean.) The data is information or instructions telling the unit what to do, and if it misses any information it will go crazy and error out. This is very different from music or video/movies that just play and if a spot is on the disc it will just be a fuzzy picture or static from that spot. If you have a disc your system likes, take care of it. I say likes because every disc has fractional differences in data location on the disc. (This is tolerance) That fractional difference could make or break the ability of your unit to read the map disc. So one possible fix is trying different disc to see if your unit will like one of them. Still eventually this also will die. These units are beyond their life cycle and the dvd drive is operating on borrowed time. I hope this helps.
Jun 22, 2014 | Pioneer AVIC-D3 Car DVD Player
No disc problem
You would only receive that error if your player in unable to read your disc, basically saying there is no disc in the unit. This problem arises mainly due to the Optical Pickup(laser) probably failing. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 27, 2013 | Computers & Internet
I tried to record a dvd and was unsucessful. Now the player won't work. I insert a disc and I can hear the player trying to read the disc. After three tries an error message is displayed saying:...
Hello
It seems that the Laser Pickup unit has some troouble with it. Just inser an audio CD and see whether the player reads the disc. If it reads, try with an MP3 disc. If these tow types of discs go with and not with DVD disc, make sure that the Laser Pickup Unit has the trouble. It has to be replaced with same type and number. Actually this is a very skilled work, as you have to disassemble and reassemble the DVD mechanism If you have confidence, and have all tools to do this work, you can do it by yoursef. Otherewise, get this set repaired, either by any experienced service technician, or by the Authorised Service Center for Panasonic at your town, I recomend you to get this set repaired by its authorised service center itself. OK.
Oct 26, 2011 | Panasonic DMR-ES46VS DVD Recorder/VCR
Liteon dvd recorder lvw1101 starts reading the dvd then says it preparing the disc then it ejects it
The Optical head unit is faulty. The disc is not being read by the head unit laser and so conveys a wrong message which ejects the cd.
Replace the optical head unit assembly but with the correct procedure.
Sep 11, 2010 | Lite On LVW-5045 DVD Recorder
"No Disc" message when trying to play DVD or music CD.
Try a "Laser Lens Cleaner" preferably one that uses fluid, run that thru the machine a couple times. You can find them at just about any retail store that sells CD's/DVD's or electronics. Next, if you have any liquid car polish, take a couple drops and spread on the surface of the disc. Use a microfiber towel to clean off. This helps clean off smudges and protects the disc from scratches. And it works great on damaged discs too! If your discs still do not play, then the unit needs to be repaired or replaced. Hope this helps
Jun 14, 2009 | Sony DAV-DZ720 Theater System
Unreadable Disc says reading and then open tray
The easiest and most permanent fix would be to install a new drive. The process is simple and does not require alot of technical skill. Get your unit back up and running good for like fifty dollars or so.
May 30, 2009 | Microsoft Xbox 360 Console
A8 2004 Navigation system not active
NAV unit uses a DVD disc. If its a copy, it may or may not work. I suggest you remove the NAV disc, unplug the NAV unit from power for 4-5 minutes, reconnect the NAV and try inserting the disc again to see if it reads. If it still does not read, another NAV disc needs to be inserted to verify its not a "bad" NAV DVD disc issue. If it still cannot read the second disc, the NAV unit is bad. The handbook feature needs the disc inserted in the slot 1 of the CD changer unit.
Feb 23, 2009 | 2004 Audi A8
Unit failed to read any discs
My unit all of a sudden fails to read any discs. It just makes noises that sounds like something is stuck. Then gives the message that its a proper disc. Its says no read.
Jun 20, 2008 | Panasonic DMR-ES25 DVD Recorder
Cannot read disc
Greetings,
I had the same problem with my Wii. Unfortunatly nothing worked to fix the problem so I called Nintendo's customer services. They were able to replace the unit free of charge. I would simply give them a call: 1-800-255-3700 and press 2.
Good Luck,
-WN
Jun 05, 2008 | Nintendo Wii Console
Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Nov 18, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Panasonic DVD-LS90 Portable DVD Player Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
