Unfortunately it will be one of 2 things that is stopping your machine from powering up 1st--The control module is faulty -2nd-- Your pump is open circuit. Now the two reasons that the control module became faulty are --1-- It faulted internally. and --2---There is a faulty part on your machine that caused the control module to fault. My best guess it will be the diverter valve.They have a wax motor in them that always faults and causes the control module to fault as well.Has your machine got an Efficiency button?If it has then the faulty part that could have caused the fault will be the drain pump,as this model has a mechanical diverter inside the pump.Please reply with the answers to the questions and i can guide you throe any repair that needs to be done.
Testimonial: "Wow-Thank you very much-we will work on it this morning-"
F21 Fault Code Repair LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
