Question about GE GSH25JFR Side by Side Refrigerator
We left the freezer door open all night...now the refrigerator will not get cold?
  • 1,531 Answers
The freezer needs to be shut down for a whole day in order to defrost the evaporator coils completely.
this can also be done by removeing the rear panel in the frezzer and using a blow dryer until all the ice is gone and then the unit should return to cooling normally
Posted on Jun 03, 2010
  • 9 Answers
SOURCE: Freezer still works refrigerator not getting cold
These are notorious for having the evaporator fan motor go bad. See www.AnyoneCanFixIt.com for the way to repair it with detailed step by step pictues...easy fix. Takes about 30 minutes or less.
Posted on Jun 07, 2008
Master_Tech
  • 770 Answers
SOURCE: Kenmore cold spot refrigerator freezer
wow you have power to the unit what about the temp control ? is it turned up?? if so is it closed(calling for cooling?) that is the place to start you can jumper it after yo unplug it to see if you dont have a meter
Posted on Jan 24, 2008
HVACRH20
  • 237 Answers
SOURCE: Freezer left open and now won't work
Try to unplug the unit from the wall and let it sit for a few minutes then plug back in. May reset the door alarm lock out. Also, moisture in the air can be drawn in and freeze up the whole thing. That means turning it off with doors open for about 36 hours... Moisture is a killer in a freezer, freezes and blocks up every air circulation vent, etc.
Posted on Nov 09, 2006
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
  • 37 Answers
SOURCE: Left door open on Sub zero model 650
It went into self protection mode. Just leave it closed and when the compressor cools down enough, it will start. Once the ref starts to cool, the lights and such will come back on.
All of this assumes that no failure was caused by the long run times when the door was open
Posted on Sep 02, 2009
Hotpoint FZFM171 freezer door left open all night, has defrosted and the 'super freeze' light and alarm light wont stop flashing. How do we fix it?
Turn the power off to the refrigerator and manually defrost the freezer until the freezer bis no longer cold and then replug the power cord
.APPLIANCE 911
Jan 27, 2016 | Hotpoint Refrigerators
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
I accidently left the freezer compartment partially open over night. Everything melted. Now that the door is properly shut it seems like it is not getting cold. How long would it take for the freezer to...
If the freezer empty it might take an hour. If there is product in the freezer it will take longer depending on how much is in there. If it does not cool down. Your evaporator coil may be iced up from trying to cool the freezer all night. To fix this problem just unplug the box and remove all the items from the freezer and leave the door open for a few hours to defrost the the coil. After this everything should be fine. I hope this helps you. Please leave feedback. Thank you.
Aug 24, 2010 | Samsung RS2534 Side by Side Refrigerator
We left the freezer door open all night by accident two days ago
I turned the fridge side off on mine, and left it overnight (last night!). This morning there is frozen stuff in the freezer. I think the compressor motor just needed ALOT of time to cool down b4 it would work properly again
Jan 11, 2009 | Whirlpool GC5SHEXNS Side by Side...
May 21, 2008 | Maytag MFD2560HES Bottom Freezer French...
Left refrigerator door open over night, next day it stopped working
sounds like you sucked in a lot of warm air over night freezer still working? just the refrig went out???easiest solution empty unit completly, unplug and leave doors open let al frost melt out 24 hrs later plug back in and you should be find
Feb 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge not cool
the coil is frosted over and no air is being pushed to the fridge it may clear up after a few defrost cycles or remove the food from the freezer and allow it to thaw completely (12hrs) the ice behind the back wall takes a long time to thoroughly melt or you will have soild ice instead of frost and then it will never thaw soild ice.
Sep 29, 2007 | Maytag MFD2560HES Bottom Freezer French...
GE GSH25JFR Side by Side Refrigerator Logo
1,351 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
