Question about Fisher and Paykel GWL11 Top Load Washer
Washer beeps at the end of each cycle,must be advanced manually
I have a GWL 11 top load and it started beeping at the end of the wash cycle (after water was emptied from tub). I pushed the start button and it continued to the next cycle (rince). It started beeping after the rince cycle was finished (after was was emptied from tub). I pushed the start button and it continued to the spin cycle.
It has also been spinning slowly for a long time before it starts beeping, like it can't figure out what to do next.
Any suggestions?
thanks,
Steve
  • Anonymous Mar 22, 2014
    how to switch of beep
  • Fisher and P... Master
  • 713 Answers
Hi Steve just read your posting.Now when it starts to beep a series of lights will light up.Starting from left to right they are numbered 1st on the left=128 next is=64 next is=32 next is =16 next is= 8 next is = 4 next is = 2 next is = 1. So the lights are numbered from left to right 128--64--32--16-- 8-- 4--2--1. now with this information look at the lights that are lit add up the value of the lit lights and reply back and i will look in my service manual and tell you what part or parts are faulty. hope this helps.
Posted on Jun 03, 2010
F&P washer stops spin cycle
You will need to check the out of balance switch under the motor controller board for corrosion and replace if faulty.
May 24, 2013 | Fisher and Paykel Washing Machines
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,...
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,Hepi
Jul 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
GWL 11 washer. Water does not come in when power
Hi just read your posting.Now what water setting have you selected?Is it warm cold or hot?Does the machine stop and beep with a series of lights that come on?If there are lights that come on when it beeps, they will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 3rd and 6th or 1st and 7th --etc--?Now if you have an LCD display what error code is it showing?Please reply with additional information and I can help you rectify this fault.
Jun 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Apr 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
END OF CYCLE KEEPS BEEPING WHILE WASHING
Maybe the machine is telling you that your load is uneven, When going through a spin cycle it will detect if the load is too heavy on one side. Just open the door and spread the load evenly. good luck.
Jan 26, 2009 | Whirlpool LHW0050PQ Front Load Washer
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Aug 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Beeping and odd light sequence
I have the same problem with my 603 washing machine stopping in the middle of a cycle and i would have to go and manually advance the wash. I have just replaced the top curcuit board with a new one. can you please help or offer a solution. Thank you.
Jun 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
192 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
