Question about Kenmore 94702 Front Load Stacked Washer / Dryer
Water is not discharging - Kenmore 94702 Front Load Stacked Washer / Dryer
  • 1,531 Answers
This could be a problem with the lid switch is the unit spinning?.
take a wet dry shop vac and attach it to the end of the drain hose to remove the water.
then remove the front panel in order to check the drain pump and make sure there is nothing clogging the pump
Posted on Jun 03, 2010
Error 20 in dishwasher AEG 77012 wop
i20 error code means:
Water is not pumped off and could be:
  • Fault with discharge pump
  • Discharge pump deenergized (faulty wiring or no activation by electronics)
  • Obstruction/blocking (filters in the appliance, discharge opening in discharge trough, discharge pump, discharge hose, siphon, cover plug at siphon connection not removed during first commissioning)
  • Discharge hose bent or connection height above 100cm
  • Ball valve in discharge trough glued / blocked (discharge pump does not aerate)
or water level inside appliance is not detected and than
could be:
  • Pressure controller faulty
  • Pressure controller hose obstructed or bent
  • Insulation fault with heating element
Dado
Feb 19, 2016 | AEG Dishwashers
Water discharge hose on heater core discharging water. why? Possibly a bad heater control valve?
T stats don't always work. Replace it again. New ones can be bad from the start.
Jul 04, 2015 | 2002 Chevrolet TrailBlazer
Where does the water discharge at on a 2000 mercury 25hp 2 stroke outboard motor?
Modern engines have a small "tattletale" discharging water out the back or side to let you know the water pump is working. The majority of the water exits thru the exhaust system to keep it cool and finally out the propeller hub when under way. There may be a small discharge out "idle ports" on the back of the motor.These relieve exhaust gas pressure when at slow speeds or not moving.
Jul 16, 2014 | Boating
Clear water coming tailpipe and muffler truck not losing water
When you start Dodge In cold weather there will be steam and water discharging from the tailpipe. The engine produces water vapour and some of this will condense in the muffler/tailpipe and discharge out of the tailpipe.
When the engine and muffler/tailpipe reaches normal running temperature you will not see any more water discharge.
Mar 02, 2013 | Metra 2006-2008 Dodge Ram 1500 Pickup St...
My sanivite 3 has a washer connected to the bottom inlet and a sink to the top inlet. when water is run from the sink the system will pump the water out, however when the washer is discharging waste the...
A washing machine discharges water water at a very high velocity and high capacity. This is far more waste water than the pump was designed to handle. The washer discharge must be connected to what's called an "indirect waste", that is, it must discharge into a laundry tub or sump, so that the excess can be stored until it can be taken by the pump. The specific code that governs this is in chapter 27 of the International Residential Code.
Also in the manufacturers instructions, they allow the discharge from a washing machine ,through an indirect waste. [sic] "The Sanivite is a drain pump that is ideally suitable for use in a basement apartment or anywhere in the house where additional fixtures are most wanted. It will pump waste water away from a variety of sources such as: a kitchen sink, laundry sink, washing machine ***(indirect connection)***, dishwasher, bar sink, etc."
This pump will never be able to handle the discharge directly and you need to provide a receptor to accommodate a washing machine. Is there any possibility of adding a laundry tub adjacent the washer and Sanivite pump?
Feb 09, 2018 | Saniflo & Saniplus& Macerator Pump
Water will not drain out of washer
Disconnect the discharge hose from the washer and look for a clog at both ends of the hose. Also, look down where the discharge port is on the washer and clear out the clog there also. If you see no clogs, then make sure your discharge hose is not crimped at such an angle to prevent water from flowing through. Also, make sure your discharge hose is not running on the floor and that it goes vertical straight 4.5 to 5 feet from the floor and then loops directly into the discharge pipe. Give that a shot. Still no water drain? Then the water pump needs to be replaced.
Feb 19, 2010 | Kenmore 80754 Top Load Stacked Washer /...
How do i prime an onga pump from repressuring to primiing
Open the priming port at the discharge pipe. Close the discharge valve and fill the priming port with water until it is full. Power up and switch on the pump. While running, slowly open the discharge valve until the water
pressure gage at the pump is 20 psi. That will be the running pressure of the pump, and the maximum opening of the discharge valve.
Sep 27, 2009 | Plumbing
Kenmore Calypso Elite Top load - water discharge question
why not just discharge into the laundry tub which will allow the water to build up but get away at its own pace through tub drain
Oct 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag discharge into wastepipe backs up, floods laundry room.
best approach is be sure to clean drain pipe build up over the years may have created partial blockage
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 94702 Front Load Stacked Washer / Dryer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
