repairpal.com > Questions > GMC > Jimmy > 1997 GMC Jimmy
Jan 11, 2011 - hi about 2 days ago i realized my brake lights were not working but my turn signal lights were working and parking lights as well but no brake ...
Sep 23, 2009 - 97 GMC Jimmy 4x4 blinkers work, reverse lights work, above window ... I just lost hazard lights and rear brake lights, they were working 2 days ... If it is a frayed wire or solder point, then you can repair it, but not any worn contacts. ... Does anyone have any suggestions on 1997 Honda Accord tail & brake lig.
Thats a big possibility. The abs light is on telling the driver the abs system is disabled. And the regular brake light could be on because the parking brake is not released.
The first thing to do is check the brake lights, if they don't work find out why and repair them, the brake light circuit powers the park lock solenoid.
possibly the neutral safety switch connected to the brake pedal is bad. when you apply foot to brake , shouls hear a click with key in run position, this would be the safety solenoid retracting itself from shift linkage, allowing shift lever to move. try pumping rapidly, but easily the brake pedal to see if you can hear click, and or shift from park.
not coming out park may a couplr of things brake switch there also a switch under center piece where the shifter is a ***** probe with test light or multa meter u can see if getting power if not getting power you want look at the key swich the mancanical side or eletircal side can be bad
there is a fuse on the fuse box call ilumination, or cluster lights
that fuse is bad
it is also posible that you have no parking lights outside
remove the fog lights power from there you need to get power from the battery using a relay
