Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Have bosch dishwasher water will not drain out what should we do?
  • Bosch Master
  • 2,605 Answers
Hello, I would first suggest accessing the drain hose under the sink and check for blockage where it attaches to the house plumbing, it doesn't take much to prevent proper draining. If it doesn't appear blocked, try draining into a bucket while you have the drain hose off, this will determine if there is a clog elsewhere. Let me know what you find and we'll follow up from there if necessary. Good luck. Macmarkus :)
Posted on Jun 03, 2010
  • Mark MacDonald
    Mark MacDonald Jun 07, 2010
    Hello again, I was hoping to get some feedback or an update on your status with the issue you had come to "fixya" for help on.. What did you find ? Did the problem get resolved ? Did we provide any assistance that was/is useful ? Please reply one way or the other as a gesture if nothing else. Myself and the other experts here put in a lot of effort and care in providing assistance which for the most part is free and voluntary, however we can be much more helpful if given some type of feedback thus knowing when we've helped and when we have not. Either way I do hope you found the problem and where able to solve it. Thanks again for using "fixya". Macmarkus :)
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
I have a bosch dishwasher #SHU46C13UC it will not drain to well
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 21, 2011 | Bosch Dishwashers
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Bosch SHU 43C06 UC17 dishwasher the dishwasher is just draining with no water in the tub, and is not filling, it does not seem to begoing out of drain mode
water in the bottomof the base remove side panel and dry out the bottom base . the float is up . thats why its in drain mode. bosch old tech speaking.
Oct 10, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
Jan 05, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher draining - Bosch SGV4313GB/17
This is generally because of a stuck diverter solenoid. The water goes to the pump and then is either sent to the wash arms or the drain. Also, check the drain.
Feb 11, 2008 | Bosch 24 in. SGE09A25 Built-in Dishwasher
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
67 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
