Question about Hitachi P50S602 50 in. Plasma TV
The tv does not turn on and thepower light blicks three times
The TV does not turn on and the power light blincks three times
    Novelist:
  • 152 Answers
Hello, the blinks indicate a fualty board or circut if you can find a service manual for your set, you can count the blinks and identify the trouble,
these circuts are working with extreme high heat so they do go bad eventually, so find a service manual and then change the part as indicated in the service manual or have a service tech service it for you that will be a bit more expensive than finding the part and exchanging it yourself but remeber to follow electronic safety procedures as these circuts store high voltages and can be very dangerous,, generally using a service manual will help you pin point the trouble .. hope this helps
Posted on Jun 03, 2010
When tv is unpluged and pluged back in it wont power on and no lights blinck
Sure the plug is getting power from wall outlet? If power is there you might want to check out the power supply board first for issues.
Oct 13, 2015 | Televison & Video
Tv turn on power light blicks three time an shuts off nothing after that
The deflection board is what causes that with your model. You need the PSB260 deflection board available at www.tvrepairworld.com listed under RCA circuyit boards. the board has a 6 month warranty and comes with installation instructions.
Jun 06, 2011 | RCA R52WH73 Projection Television
When the tv is turned on i hear a click the red light turns on then another click and the red light blicks. is there a reset
Count the number times the red light blinks this is an indication of the error code as to what the probem is, if it blinks 10 times then this is a power supply failure.
May 21, 2011 | Panasonic TCP42C2 42 in TV
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Jul 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Power on for 5 sec and then turn off and blinck 8 times
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
May 28, 2010 | Sony KP-61HS30 TV
Code to enter service mode
Forget the service mode. The tv power supply regulator has probably failed.
Oct 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV will not turn on, Have three blinking lights, lamp won't turn on, color wheel isnt spinning.
the color wheel wil need to be replaced soon if it is doing that. it could be then DMD board as will.
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Sony kp-53s10
Power supply or scan failure is the usual cause. You will require service for this set.
Jerry G.
Apr 13, 2008 | Sony KP-53HS10 TV
TV repair
that is a diagnostic code. But need the model number of your set to identify the cause of the error code.
Mar 10, 2008 | Televison & Video
Hitachi P50S602 50 in. Plasma TV Logo
133 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
