Question about Goodman CKL24AR24 Air Conditioner
My bryant air conditioner will start and run for about 45 min. The fan stops and then the breaker trips. I wait for 30 min and re-set breaker and sytem works again for about 45 min. Is this a defective fan or capacitor?
    Guru:
  • 1,524 Answers
Motor windings are over heating. Change the motor.
Posted on Jun 03, 2010
Bryant condenser not running.
Check that there's power available (open or tripped breaker or disconnect). If there's power available, check for 24-28 volts feeding the contactor coil. The low refrigerant cut-out may have tripped the 24v (leak). The pressure cut-out may have tripped (dirty condenser coil, inoperable condenser fan motor). If there's 24 volts at the contactor coil, check the capacitor before ohming the motor. A defective run capacitor will shut the compressor down.
Aug 27, 2013 | Bryant Legacy 16 Series 4.0 ton AC...
Duo therm mod. 57915 air conditioner seems to work good , runs for 4-5 minutes then kicks breaker , was kicking 30 amp breaker at camp ground , i've been working on connections to make sure its...
Unit may pull as much as 17-18amps when compressor starts up, but level out to 12-15 amps when up and running. Keeping in mind that is all relative to proper 120v incoming voltage, heavy enough wire to run the application etc. If your AC unit needs cleaning , it may draw an extra amp or 2 . With that said, when your at the park, first thing I'd question is their incoming voltage to RV, and try running fridge etc and anything else on propane if possible. The AC alone should not cause 30amp at source breaker to trip, before 15 0r 20 amp breaker in RV that is connected to AC trips. If it doesn't trip your breaker at home, and all is connected same at park, then I certainly would suspect bad breaker or voltage/wiring at park is the cause. P.S. I noticed you said you have 12 gauge wire (rated at 20 amps) connected to a 20amp breaker at panel, but RV is plugged in to a 15amp receptacle, I will assume with a 15 amp adapter from 30 amp plug. Do you see any hazard regarding 15 amp rating on receptacle? ( just a little advice.)
Aug 15, 2011 | Dometic Rooftop RV Air Conditioner
My ac condenser keeps poping a breaker near th reversing valve
Before it trips, is it blowing cold air? If not, you could have a defective compressor start capacitor. Does the top fan spin? If not, its more than likely the start capacitor.
Jan 27, 2011 | Bryant 463AAC008BA Air Conditioner
My colman rooftop ac unit shuts off after 5 min of use wait 5 more and you can turn it back on again when its running it works great its on a 1984 holiday rambler and has very low hours?
Try a new fan motor. It runs about $125.00, It will run a few min. then will trip the motor themal switch. you can probably still here the compressor running. It may also trip the breaker on shore power . good luck! the part you are looking for is a 1/3 hp 115vac 2 speed 1580/1020 rpm part number #1468-3069
Aug 25, 2010 | Coleman Mach III Air Conditioner
No power to ac unit
Check the breaker for the unit or check to see if the disconnect by the unit in the attic has fuses that may be blown.
If the breaker is tripped or the fuses blown, then check to see what caused them to blow...
heatman101
Aug 01, 2010 | Bryant 463AAC008BA Air Conditioner
Soleus mac 12-k air conditioner runs for 45 mins then trips breaker. i reset and then 20 mins later shuts off again.
first of all an amp reading needs to be taken to see how many amps the AC is drawing. It may be too much for the breaker. Also see what else may be wired in on the same circuit, there may be additional load on the breaker. If all amp readings are below the rating for the breaker then you may have a faulty breaker, but that's pretty unlikely. The most probable cause is you are overloading the circuit.
Sep 14, 2009 | Soleus MAC-12K Air Conditioner
Air conditions trips circuit, wont stay running.
Is it a window unit?
Did you check that the condensor coil is free of dirt?
Is the Fan motor running or does it stop before the breaker blows?
Jul 29, 2009 | Kenmore 75085 Air Conditioner
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
Code #33 on Bryant 355MAV 90i Furnace
'Limit or flame rollout switch is open'. In my case, the flame rollout switch had tripped due to an overheating? I had to push the button between the wire leads to reset the switch. Then when I turned the power back on, the furnace started up like normal.
Why did the switch overheat and trip? My current theory is that there was a rubber grommet around a pipe near the switch that had slid down and was no longer sealing the furnace?
Mar 01, 2009 | Goodman CLJ30AR32 Air Conditioner
Goodman CKL24AR24 Air Conditioner Logo
149 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
