Question about Panasonic Televison & Video
I just bought a TCP65S1 and so far almost every time I turn it on I get static, but after fiddling with it I get the picture....any ideas what it is???
  • bpeter2345 Jun 03, 2010
    This tv is brand new. Any other explanation as to why I get static before turning off the tv and on again to get my hdmi picture???
  • Panasonic Master
  • 1,216 Answers
Hmmmmm, I would guess you are referring to the colored squares or rectangles that move across the screen. This would be the signal board that is not working correctly. If this TV is new, please, by all means call the 1 800 number and discuss this with the customer service. Your warranty will help you repair this. Or you may take your sales slip back with you and find the store and service counter and see if you may replace this TV. Remember you are the customer and always use diplomacy when discussing your problem. Remember diplomacy is the key here and will most certainly open doors for you! Good Luck and thankyou for asking!
Posted on Jun 03, 2010
  • matt martin
    matt martin Jun 03, 2010
    It can be a loose ground. A poor connection from the powersupply to the signalboard. A defective signal board,a microprocessor with logic confusion etc. All products are engineered to give you the best result, unfortunately some products will have a failure. It is always in the consumer's best interest to read warranty info, as this is the manufactures way to help you receive the best possible working product. Yes...you are in the best interest of the manufacturer. Thanks for asking and good luck!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with you’ll have to open the back of the unit, then check the power supply board and check for bad components. As the power supply board develops high voltage to supply to all components so you should check that board for any bulged capacitors and if you have electrical expertise you can also check that board/components in a better way. These issues usually happens due to overheating in plasma TVs after sometime, as these sets are very hard working device and produces a lot of heat. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
    Is your solution to my problem normal or do you think my TV may be defective?
Static sound builds up in the sub pops, then no sound comes from it. The sound comes back once I reconnect the power source and fiddle with the power plug. The problem then repeats.
Look for a wire strand or solder splash on any circuit boards or connections that might be 'almost' shorting out anything. Next, if there are any metal screws with very pointy tips (like sheet metal screws) that might be just a smidge too long and clip the very tip off so that it can't possibly short a frame to a component.
The idea is to find any reason why electricity might be bleeding over into another area of a circuit board that uses capacitors where a charge could build up causing the symptom you are describing.
May 09, 2016 | Altec Lansing Audio Players & Recorders
Cordless phone static
It may be interference from an electrical appliance, try turning appliances off one at a time to see which is faulty, ensure home unit is far away from other appliances
Aug 09, 2014 | Vtech 107944 Digital Cordless Telephone...
Engine knocks
no engine option stated, so , impossible.
the dizzy timing is way off, if in fact its a dizzy car. (distributor)
if not dizzy the cam CMP sensor is loose or some one fiddled it blind.
timing way to far advanced
so use a stroble light and set the timing to spec reading how to do that
in the FSM. (open hood lookup there is the static timiing spec, right there on all usa cars 1998.
to set timing the book shows the timing freeze jumper.
EFI needs that.
dont drive an pinging engine, or the pistons will shatter.
i warned you !-
Jul 08, 2013 | 1998 Honda Accord
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
Have a digital decor 8'' picture frame
I have the same problem, there is a way to get it back on, but it is neither easy nor consistent. I had a power outage at home and it died and was hissing static noise. I have gotten it to come on by cycling the power both by plugging it in and out, and also cycling the power switch as well as fiddling with the contrast thumbwell. Sometimes it comes on right away, other times I have fiddled with the power cord, power switch and contrast for 30 minutes. I does seem to work though not a consistent pattern. I have lost power here several times and I seem to always be able to get it back on.
Aug 05, 2009 | Alpha Digital Electronics - Others
Damn Blinking!
You can buy a used monitor about $50.00 in the US. or You should take the monitor to an authorized repairman. IT IS NOT recommended to fiddle by banging a defective unit WHICH has HIGH voltage running through it.
Jul 26, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Viewsonic LCD TV - Picture/Sound goes out after 1st power up
Hi visceran,
I am happy to help, unfortunatly your main/input board is malfunctioning, it is a problem with the processor. I had a 32' Viewsonic on my bench last week with the same symptoms.
If the tv is new you should contact Customer Service asap, also check on the return policy of the store you bought it from. Many times it is alot easier to return to the merchant than to ship to repair facility.
Let me know how it goes and if you need further assistance.
Please rate this solution. Lone99star
Jan 23, 2009 | ViewSonic N3735W 37 in. LCD TV
Static
where do you live? are you in maryland?
Nov 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Black out on my LED screen
This is an intermittent failure of the CCD There is nothing for us to help you with in my opinion- Your camera is dying. Depending on how old your camera is and the date of manufacture it is possible that Canon will replace it or supply a refurbished one for free. This is known problem as far as I can tell
Sep 21, 2007 | Canon PowerShot A520 Digital Camera
Televison & Video Logo
20 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
