Question about Cobra 29 LTD CB Radio
Not enough audio and i dont want a power mic i
Not enough audioin my 29 ltd and i dont want a power mic i want to cut the limiter
    Genius:
  • 1,274 Answers
Take off the cover, you will need a watt meter or mod meter to do this. On the circuit board, part side up, look for D11, and cut one end of it, hook up meter, key the mike and with a peaking or tuning tool, while saying aaahhhhhhh in a long and steady voice, tune L12,L13,L14 for highest peak, you can get the tool there also..put cover back on and enjoy.....hope this helps...
Posted on Jun 03, 2010
When do you know if you have a decent radio
The 29 has a built in SWR meter--check the match to make sure it is below 2 (lower the better).
The radio can be peaked for better than factory audio.
If the squelch is up too high you will not hear people below a certain signal level---in your case set it so you hear who you want to and not jokers.
RF gain lowers signal the radio sees for receive.
The stock mic will work but make your voice somewhat flat sounding---a power mic or having the mod limiter removed will make the radio and your voice louder.
Let me know if questions.
Jun 10, 2012 | Cobra 29 LTD CB Radio
How do I adust the watts on my cobra 29 ltd CB
Replace the 2314 driver withe a 2SC2166 driver and the final transistor with a 2SC1969 final transistor. Re-tune coils L10,L9,L8 for maximum power. Don't cut d11 like some may say to. It will turn your radio into a crappy sounding radio. Simply adjust VR4. Never cut a limiter. This will get you some solid sounding power.
Mar 06, 2011 | Cobra 29 LTD CB Radio
How to ajust my cobra 29 to so it will get out to talk
First check the swr's. make sure you have a good antenna, like the 108" whip, others will limit your range, because they are shorter, stay with the longer 7ft types like the predator 10k, or wilson 5000 magnetic mount.
Then just adjust the modulation variable resistor for minimum resistance and it will let your radio have full output power. No cutting!!! Check it with an oscilloscope and watt meter, and check the frequency with a freq counter.
Other things, good quality echo mic. or power mic (cobraHM75$17.99), or even a RK56mic($38.99)...
Mar 02, 2011 | Cobra 29 LTD CB Radio
Hello i own a cobra 29 ltd classic from 1993 today i was talkin skip like crazy!! running about 100 watts out of a texas star modulator!! i left for a while came back talked for a while everything was good...
sounds like the amp got hot and shorted on the bias.. and is keyed up a few watts. to fix you will have to have the amp repaired. new power transistor. to fix. 3174269649 Texas.
Dec 12, 2010 | Cobra 29 LTD CB Radio
Cobra 29ltd CLassic, TX power and audio is ok, volume from spkr is good, squelch works but no cb recieve.
Try a new Mic. Make sure its a working mic. If you have a bad mic, the receive will not work.
Aug 22, 2010 | Cobra 29 LTD CB Radio
I have a cobra power mic that has no audio output
Sounds like its not wired up right, the audio wire must be off,take the plug apart and check the white wire, re-solder it. here is the wiring, pin1-shield,pin-2audio-(white), pin3-transmit-(red), pin4-receive-(black).....hope this was helpful...
Apr 23, 2010 | Cobra 29 LTD CB Radio
I don't have voice, have carrier. Cobra 29 ltd
there are several things that might be responsible for the absence of modulation when speaking into the microphone. a defective mic cartridge, a broken audio or audio shield/ground wire in the mic cable or mic plug or a defective push-to-talk switch in the mic itself, for starters. if all is well here then the amc and transmitter speech stages in the transceiver will have to be considered next. locate and check with a known good mic wired for the radio in question. let me know.
Jun 06, 2009 | Cobra 29 LTD CB Radio
Where does the pin on a mic go to on a cobra 29 ltd
1/ shield 2/ audio (usually white,it's the wire the shield is wrapped around) 3/ red 4/ black if the radio transmits without keying the mic. switch # 3 and # 4.Good Luck
Apr 25, 2009 | Cobra 29 LTD CB Radio
How to wire a power echo mic up theres 5 wires and 4 oins
I suggest buying a 5 pin to 4 pin adapter. Ebay has them for $6. I would go chopping wires on the mic. Cobra 29 ltd is a nice radio. Have one myself.
Cobra 29 LTD CB Radio Logo
401 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
