Question about Watches
Need to replace a watch battery
I have a ladies watch - Charles Jourdan with the word TECHNIC written on the backplate. How do I open this watch to replace a battery - unscrew or lever off the back plate?
SOURCE: skagen ladies watch
izzi, I assume you have a snap back back that won't snap back in place. I had the same problem with a Timex EXpedition. The solution should be similar. See my post" http://www.fixya.com/support/t190459-watch_battery_replacement and also the site I reference there. http://www.online-batteries.co.uk/whichbattery.shtml Good luck, Richard
Posted on Sep 28, 2007
  • 11 Answers
SOURCE: bulova 96R19 ladies diamond chronograph
Watch shops use a press to put backs on. Some will snap on using your thumbs, other need the press to apply more force.
Posted on Feb 16, 2009
SOURCE: How do I open my watch to replace the battery. Looks as if I need a special gadget.
Get a small screwdriver and a file, file the end of the screwdriver down to a fine edge, thin enough to fit the narrowest gap, then carefully lever the case open. Try to avoid being heavy handed, you do not want to scratch the watch when doing this. HTH.
Posted on Jun 10, 2009
  • 65 Answers
SOURCE: How to Open a Gucci watch
Most watches are either screwed on and typically have a series of small notches around the circumference of the case back. A special tool is generally called for. Otherwise they are "snap back" . These are simply pressed on. To remove you can carefully use a regular knife in the absence of a "case knife". There is usually a small gap/groove/notch area to insert the balde and lift the back off.
Posted on Jul 25, 2009
  • 110 Answers
SOURCE: Can't get the back plate of a Timex Indiglo WR30M watch back on
It is either a screw on case back or a "snap-on. I suspect that it is the latter since you don't mention that you used a tool to unscrew the case back. So getting the back on sometimes is very difficult. I have a special tool for that to apply even pressue and the necessary force and does not put pressure on the crystal. You have to be careful to not damage the crystal. If you don't get it done, then suggest you take it to a shop that has the right tool. If you have very strong thumbs you might get it done.
Posted on Dec 06, 2009
I need a backplate screw for a ladie´s Parsifal 9988
Fixya does not sell backplate screws for Parsifal watches.
Feb 19, 2018 | Watches
Need to change battery in Armitron Now ladies watch 75/2475. How to do it. How to you remove the back on the now 75/2475 watch
Take your Armitron watch to a jeweler for a demonstration of how to open it. While there, you may be able to persuade the jeweler to install a replacement battery, all for a reasonable sum.
Feb 10, 2018 | Armitron Watches
What size battery dos my Gucci 1 980 003 series ladies watch need
Take your Gucci watch to a jeweler who will open it, identify the battery type and perhaps install a replacement for a reasonable sum.
Sep 21, 2017 | Gucci Watches
Battery size for emporio armani ceramic ladies watch
  • To determine battery type: open back
  • Locate battery holder and identify type. Note battery mounting
  • Place opened watch in plastic bag to keep it dust-free while you obtain a replacement battery
  • Remove watch from plastic bag and install new battery
  • Check operation
  • Install back
Finally, reset watch as necessary
Aug 28, 2016 | Emporio Armani Watches
Change battery
Usually, you remove the backplate and then the battery. Replace the battery without touching it by hand and replace the backplate.
Mar 08, 2015 | Watches
Watch flashes--why?
Flashing means low battery. Time to replace it.
Mar 14, 2013 | Breitling NEW BREITLING WINDRIDER COCKPIT...
6617, I am unable to set the time.
yes the stem should pull out if it wont pull out unscrew it first by turning it anticlockwise then pull out,,don't forget to screw back in after you've adjusted..
Feb 01, 2013 | Charles Hubert Classic Ladies Silver Tone...
Beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
May 31, 2009 | Timex Watches
May 06, 2009 | Watches
Open back
Hi cinannh,i have sample video guide of how to open ,tell me whatever the result ,so i can assist...
How to replace a watch battery - Watch
hope this may help;
Regards,
VOTIT
Jul 30, 2008 | Pulsar PPG672 Ladies
Watches Logo
158 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
