Insignia 32" 720p Flat-Panel LCD HDTV Logo
Posted on Jun 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ramdom channel searching
As you turn tv on automaticly goes into channel search nonstop
Anonymous
Level 3:
President:
  • Master 1,285 Answers
  • Posted on Jul 10, 2010
Anonymous
Master
Level 3:
President:
Answers
1285
Questions
Helped
297056
Points
3126
You must go to menu / tools settings and switch the auto channel scan off and just set it to ch 3 (for cable/dish) or to channel you wish
Automatic channel scan on daewoo tv
What is the exact model number to your Daewoo TV?
Hi, i have 14 "
As I see it, your problem has something to do with your remote. I bet you have pressed the "auto search" button of your remote that's why your TV keeps on searching channels automatically from channel 76 down. Here's what you've got to do:
1. Get your remote control
2. Turn on your TV.
3. Press the "auto search" button to stop your TV from automatically searching channels.
4. In case it works, I'd advise you to look for channels manually using the number buttons or the "previous" or "next" buttons.
5. If it doesn't work still, contact your technician or your service provider about it. They are of great help for you!
I hope it helps. Thanks a lot.
As I turn on TV it keep automatically switching between channels and I cannot fix one specific channel. I tried to disconnect/connect and it continues to do so
maybe ur tv is on search channel mode. check the menu panel and look for the tv's browse channel option turn it off. also read ur owner's manual about how to browse channel automatically.
1helpful
Tv tuning instructions how to?
The quick user guide is available here: F32648 F36648
Tuning is automatic on this TV, ensure that auto channel search is on from menu.
Advanced Auto
Channel Search
Auto Cable/Air Switch sets tuner
to cable or “off-air” frequencies
during initial setup. Then system
automatically scans for and locks
active channels into channel
memory.
1helpful
Can`t receive all t.v. channels
get a menu of the tv and enter into a channel searching select auto and press search, automatically your tv will start searching. each signal found will be stored on each one channel.
later just store those channels into the memory of the tv.
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
How to program the TV to utilize cable channels
Go into the menu on your tv via built in button on the tv, or the remote. Look for something that reads "Program Mode" or "Program Channels"
Tv's have to search for channels that have a good solid frequency if they are just hooked up. newer tvs do it automatically
I have a Magavox television and the channels will not show . All channels are fuzzy. It will get only numbers starting with channel 49. I need to do a channel search to get all the channels to show.
have a magavox tv combo, with dvd and vcr. It will not stay on unless you put a tape in and spend 30 minutes to an hour turning it on and it goes off automatic. Less than two years old.
Continuous Channel Searching & Power Button Issues
What source are you using? If cable, you should only be able to pickup channel 3 or 4 if you're using the box. If there is no antenna, that would be the only other answer if the set checks out...accordianman
RCA TV model 32V420T - Auto channel seek
Hi there!
Check that the remote buttons or the buttons on the Tv has not become sticky or soiled on the inside. Good Luck, JUS004
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
