Go ahead and right click anywhere on your desktop, select personalize and from there select your favorite image, then just center it, stretch it, etc.
that is the way for Win7 I believe is the same for Vista and Xp.
You can try to uninstall the Ask toolbar. Try uninstalling it with Revo Uninstaller. Revo first uses the APN's own uninstaller. Then, depending upon what radio button you have ticked, it can also pursue registry settings associated with APN that the primary uninstaller missed. You can manually select or unselect any that you want to remove or keep. The updater is a persistent thing that may reappear afterwards unless you clean out sufficient settings. You see, if the updater changed settings in your browser, simply uninstalled the toolbar is insufficient. So, below are instructions which may pertain to your specific browser.
You can try the manual uninstall directions on this page:
to create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help click on the tools at the bottom of the drop down list will be internet options or click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (AAA.com) or your preferred home page and browser below that will be change search defaults click on settings you will see all search providers you
if this is a window operating system,
right click any blank space on the desktop, and click property or personalize depending on your o/s, then select then select desktop backround
mcdevito75 here, Yes you can change the theme or your monitors backround look. Click Start, the control panel, the Appearance and themes, then Backround, here you will find your coice of backround themes for your monitor, once you choose which theme you click ok, and your done.
happens with a mixed ground issue. I had same thing with my laptop. only way to avert this is to super ground your digital sound devices...and connect them to ground/chassis of the desktop, if that's your option. used to be called 60 cycle hum in olden days. check your computers warranty here 4 FREE
