Question about Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100
A problem has been detected. i boot it from cd and after the windows setup it displays" a problem has been detected and windows has been shutdown to prevent damage to your computer the problem seems to be caused by the following file: partmgr.sys page-fault-in-nonpaged-area if this is the first time youve seen this stop error screen restart your computer. if this screen appears again follow these steps! check to make sure any new hardware or software is properly installed if this is a new installation ask your software manufacturer if problems continue disable or remove any newly installed hardware or software , disable bios memory options such as caching or shadowing your computer press F8 to select advanced startup option s, and then select safe mode. technical information: *** stop :0x00000050coxf7aed4ab,ox00000000,0cf7aed4ab,0x00000000 *** partmgr.sys address 47aed4ab based at 47aeb000 datestamp 000000 00" how to fix it?? please help
  • Robin ray Derro
    Robin ray Derro Jun 10, 2010
    when i format the hard drive it says disk error
    President:
  • 2,351 Answers
If you're running Windows XP (Any version) or Vista open the link provided below for instructions on how to repair you're master boot sector other wise known as fixmbr; http://helpdeskgeek.com/how-to/fix-mbr-xp-vista/
Read everything.
Mike
Posted on Jun 03, 2010
  • Mike Peluso
    Mike Peluso Jun 10, 2010
    In you're case, find the hard disk drive manufacture name which is printed on a sticker on one side of the drive. Lets say you're hard disk drive is either a Seagate drive or a Maxtor drive. Download SeaTools for DOS from the link provided; http://www.seagate.com/ww/v/index.jsp?lo...
    Once downloaded you'll be able to create a bootable CD or a bootable floppy disk which you'll be able to run their software in a Dos like mode. See the tutorial on the site. For Weatern Digital drives go here; http://support.wdc.com/product/download.... For Samsung drives go here use, (ES-Tool); http://www.samsung.com/us/business/compo...
    Each program will test you're hard disk drive for problems and most of the time it can repair problems. All drive manufactures have software to test and setup both IDE and SATA drives. All allow you to check, setup, repair and format these drives. Keep in mind all of these will erase any and all data currently on the hard disk drive. Once completed you shouldn't have a problem installing an operating system. If the software finds a problem that can not be repaired and if the drive is still under warranty, themanufacture will replace you're drive.
    Hope you fine this helpful!
    Mike
Microsoft Windows error while booting
This is most likely bad RAM. You can download Memtest86+ for free from memtest.org and burn it to a cd. Then put the cd in your broken computer and turn the power off and on. If you manage to get it to boot from the CD it should scan your RAM for any issues it can find. If it finds errors with your RAM you will have to buy new RAM. You can either bring it to a repair shop or you can buy the RAM and put it in yourself from Newegg.com. Make sure you look up your computer's model number and order the right type of RAM.
Jan 31, 2014 | Microsoft Windows Anytime Upgrade Windows...
Message displayed- problem detected and windows has shut down to prevent damage. Restart using safe mode-tried this but it did not work. Tech Information STOP OXOOOOOOED Unmountable-_Boot_Volume
If this is a corruption it may be fixable, again this depends upon your version of windows, however please be aware this may be a corrupt hard drive so you may need to replace this and reinstall.
Try this first
  1. Start your computer by inserting the Windows startup disks or the Windows installation disk if your computer can start from the CD drive.
  2. When the Welcome to Setup screen appears, press R to select the repair option.
  3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console.
  4. Type the administrator password when you are prompted to do this.
    Note If no administrator password exists, press ENTER.
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER.
  6. At the command prompt, type exit, and then press ENTER to restart your computer.
  7. After you repair the volume, check your hardware to isolate the cause of the file system damage.
May 11, 2011 | Dell Computers & Internet
I m unable to install xp on dell vostro 1015 with 2 gb ram and intel core 2 duo cpu (t6570) ( the laptop came with preinstalled windows 7 and i have also successfully installed red hat linux 5 server...
If you try to run XP setup without changing the BIOS SATA setting to ATA mode, setup will BSOD with an 0X0000007B error. Make sure the SATA setting in the BIOS is ATA...
you will get this error when you will be booting your system from CD and windows installation will be in first step.
to resolve it, go to BIOS setting-->change BIOS SATA setting to ATA mode--->apply changes-->insert windows CD and restart the system-->press f12--->nd boot from CD....hope u will be able to resolve it.
Oct 12, 2010 | Dell Vostro 1015 Laptop
My PC with 865PE Neo2-FIS2R doesn't boot on SATA HDD... It actually runs windows server 2000. but after an unexpected power shutdown... the pc always boot on Managed PC Boot... upon checking on the Boot...
Hi Good day!! well i think your board didn't detect your HDD for some reason:
1. unexpected shutdown
2. cable not properly connect in HDD to motherboard
3. HDD have been damage because of improper shutdown.
here are the step to detect your HDD
1.pull out your cable from the HDD and then re-insert it make sure it its inserted properly.
2.go to CMOS and then in the "MAIN menu" check the primary master, primary slave, etc. in the primary master your HDD should be detect there. if not enter your primary master for auto detecting.
if nothing happens and still not detected you must replace the cable of your HDD.
Pls. Reply to help you more
Regards
JR
Oct 07, 2010 | MSI 865PE Neo2-FIS2R (MS-6728-030)...
When i plug the hard drive my computer wont detect. only the bios can detect.and i cant reformat it it says.a problem has been detected. i boot it from cd and after the windows setup it displays" a...
This usually happens when u fit any hardware to the system....The information which u gave seems its "Blue Screen of Death" or "BSOD" ........ if u have seen this screen only after u plugged in yr HDD, try with other HDD. Perhaps there might be an error with the HDD which u have plugged in.
Jun 13, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Insataling windows xp problms
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
May 14, 2009 | HP Compaq Presario CQ60Z Notebook
My computer shut down windows to prevent damage from my computer
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there.
Sep 27, 2008 | Compaq Armada E500 Notebook
Automatically stops and starts
This is usually because of a bad driver. Boot the computer and press F8 every half second until you see a black&White text menu - then choose safe mode boot
If it does boot then try System Restore back to earlier point in time.
Report back what happens?
Aug 17, 2008 | Acer Computers & Internet
Computer
windows are corupted somebody has forced ur computer to shutdown manually u need to repair ur windows first by the windows cd or needs to perform clean installation
May 20, 2008 | Gateway GT5220 PC Desktop
Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100 Logo
361 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
