Question about Kenmore 66832 Dryer
Not heating...replaced the thermal fuse and still not heating
  • 1,531 Answers
There is more than one thermal fuse in the unit.make sure to check the heating element for continuity as wells as your thermal fuses.
Posted on Jun 03, 2010
TheMobilian
  • 8220 Answers
SOURCE: dryer wont heat up already replaced thermal fuse
You gas coils are probably old and weak. check this out
Gas dryer works and quits
Posted on Apr 11, 2009
  • 12 Answers
SOURCE: Whirlpool electric dryer
either you are pushing the dryer back to far and crushing the exhaust vent hose .your exhaust vent going outside is stopped up , or your low temp thermo will not let the dryer cycle and it is over heating.
Posted on Feb 28, 2008
  • 188 Answers
SOURCE: no heat
Check the home electrical fuse panel or reset the breaker (even if it looks like it's not tripped).
Posted on Feb 19, 2009
canbruce75
  • 1776 Answers
SOURCE: maytag dryer model #mde6657byw wont heat replaced
Check the switch mounted on the motor. Two of the terminals are for the heater element operation. Other causes could be a faulty heat selector switch or timer. These components can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity indicates a faulty switch. These are some items to consider. Hope this helped and best wishes.
Posted on Aug 31, 2009
dmftrucker
  • 1922 Answers
SOURCE: whirlpool GEW9200L not heating up, i have replaced
not being sarcastic, but, your sure you have 240 volts present at the unit? then check door switch heat section control of switch may be bad
Posted on Oct 09, 2009
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
    If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
    Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
    Instructions And Things You'll Needed.
    • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
    1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
    2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
    3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
    4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
    5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
    6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
    7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
    8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
    Thanks for using fixya.
    Jul 31, 2011 | Kenmore Dryers
    Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
    If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    My maytag electric dryer wont heat up
    A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
    Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
    My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
    dryer_heating-element.jpg Heating Element
    dryer_thermal-fuse.jpg Thermal Fuse
    dryer_thermostat.jpg Thermostat
    dryer_timer.jpg Timer motor
    Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
    My dryer will run, but will not heat.
    Hello there
    Heating Element
    Thermal Fuse
    Thermostat
    Timer motor
    Jan 25, 2010 | Speed Queen AES28AWF Electric Dryer
    Heavy duty kenmore dryer model # 76680100 not heating up to dry cloths
    Hello there:
    please try this
    Proper Voltage
    Jan 19, 2010 | Dryers
    Whirlpool dryer will not heat
    Hello there:
    There are 5 things that would not make the dryer heat up i will post you them here ok
    Jan 17, 2010 | Dryers
    There is no heat to dry clothes.what do I do?
    My dryer will not heat up.Investigate these five areas if your dryer is not heating up:
    Proper Voltage
    If your dryer won't heat up, it's possible that it is not beingsupplied with the proper voltage. Here are three ways to make surepower is getting to your dryer: First, make sure your dryer is pluggedin. Next, check the circuit breaker panel to make sure all the circuitbreakers are in the correct positions. Finally, check to make sure nofuses in your fuse panel are blown. Any of these could explain whypower is not getting to your dryer.
    Heating Element
    It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
    Thermal Fuse
    Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
    Thermostat
    If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
    Timer motor
    A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
    Jan 12, 2010 | Kenmore Dryers
    Kenmore Dryer won't heat up
    thermal fuse is bad. replace fuse. clean out vent duct. thermal fuse usually blows when there is restricted air flow over heating element.
    Jun 24, 2009 | Dryers
    Kenmore 66832 Dryer Logo
    156 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
