Question about Logitech X-530 Computer Speakers
Speakers not working
I changed desks, so had to remove speakers temporarily (few hours). I have done this multiple times, no problems. This time, when I turned the computer back on, the speakers no longer work. I installed the wires correctly. The "Green" light is on - even checked my computer system to make sure the audio was working - it thinks it is. I've turned the computer on and off. Emailed SONY for my VAIO to get help - ran through all their instructions - still not sound =(
    Scholar:
  • 67 Answers
Check the easy stuff first: make sure the volume is at a reasonable level and play sounds from multiple sources like pandora, youtube, a local mp3 etc to make sure issue is consistent.
Next make sure the one or more wires are plugged into the correct ports. Or at the very least the green wire is plugged into the green plug on the computer (unless they're USB speakers?).
You could always look at the sound settings of Windows and see (if your sound card has multiple plugs) if the plugs and assigned different functions (base speaker versus microphone/headphone etc.). Hope this helps!
Posted on Jun 03, 2010
Hitachi 51F710E has no sound
The audio portion of the main board is failing. You can get a replacement here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 07, 2017 | Hitachi 51F710 Rear Projection Television
System worked for 2 hours then shut off came back on a few times
It shuts down to protect itself from overheating, looks like you tried to use it too much without sorting the problem out.
You can try and give it a good clean out. Google cleaning computers.
I usually use a small brush, my vaccum cleaner and sometimes an air duster
Jul 26, 2010 | Spherex Xbox 5.1 Surround Sound System...
Monitor problem
Your monitor is sensitive to magnetic interference from your pc speakers, place them away from the monitor at all times then the montor should go back to normal within a few hours or so. you could try to degause it every couple of hours or so but this will not totally fix the problem, leaving the monitor switched off for a period should work better.
Jun 27, 2010 | Computers & Internet
I cannot log into facebook. When I try to log in it says "your account is temporarily unavailable due to site maintenance. It should be available again within a few hours. We apologize for the...
This is a problem with facebook servers. It is not the first time this happens to some facebook users.
It works for your friends because there accounts aren't on the same machine as your. Large websites like facebook have multiple servers machines not just one. They are currently working on the machine that contains your data so it is unavailable, like the message says it should be back in few hours when they finish with the work.
Jun 20, 2010 | Computers & Internet
Having speakers to work on vizo desk top . all in on desktop!
You need to remove the unknows first. Try the speakers on another device. You could try a walkman, another computer or anything with an 1/8th" Stereo jack. Prove that the speakers work or get a pair of headphones to check out your PC. If you are using the green jack on the back try the headphone jack on the front. If the front works and the back doesn't check the sound card options / set up. Some have an icon by the time in the bottom right corner others will need to be found under the sound effects manager or the sounds and audio devices icon. I suspect if you get this far something has been turned off in the software.
May 11, 2010 | Sony VAIO VGC-RB34G PC Desktop
Only used a few times and the power is on but nothing showing on the screen and theres no sound its a black ds lite
The reason the screen isn't showing-up is probably because of runny colors or blotchy colors permanently stained on the screen, even when the Nintendo DS Lite is OFF, my guess is that the liquid crystal display (LCD) is cracked. And also, there are multiple reasons for your speakers not working properly. The main reasons for the speakers not working would be the following;
  • Something small must have gotten wedged inside of the speakers.
  • A type of liquid and/or sticky substance leaked into speakers.
  • Lots of pressurized force on upper screen(which could have also caused the damage done to the screen).
What I would recommend is make an appointment with "Nintendo customer service".
Feb 16, 2010 | Nintendo DS Lite Black Console
One speaker sucks.
this is either a bad cable or loose soldering. Inspect for physicaly damage and either replace the cables or the speakers all together.
Jun 03, 2009 | HP Compaq JBL Pro (401508-001) Computer...
Want to use old desk top computer speakers with laptop
The headphone jacks on laptops do not provide a DC voltage to your speakers only a low powered audio output that will not provide enough power to drive most desktop speakers. If you want to do this you will probably need to get a set of speakers with an external power source. Then it should work fine(providing a headset does work in that jack).
Mar 29, 2009 | Dell 5650 Computer Speakers
Hissing Sound in Creative SBS 560 5.1 Speakers
Have you check to see if you have the correct driver for the sound card. I know for fact that when reload some mother board that have a build in sound card that carries AC97 drivers it will install or download the AC97 driver with no problem,and no error and it will not work because the driver needs to be upgrade. You might need to get a new sound card. simple and done. Or go through the trouble to find the correct AC97 driver.
good luck
Jun 11, 2008 | Audio Players & Recorders
Logitech X-530 Computer Speakers Logo
241 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
